この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Use this guide to remove and replace the charger connector in the Nokia 6010.
必要な工具と部品
Press the small tab on the bottom of the back of the phone.
Push the back case upward towards the power button. The back case will then pop off.
With one hand, press the ridged tab near the visible side of the SIM card.
Slide the card out with your other hand.
Grip the phone on either the sides, the top, or the bottom.
Pull the front case away from the rest of the phone.
Remove the six screws around the front of the phone body with a T6 screwdriver.
Insert a spudger tool between the phone casing and the charger connector.
Pry the key away from the phone gently.
ある他の人がこのガイドを完成しました。
