メインコンテンツにスキップ
Nokia 6 Disassembly
必要な工具と部品
  1. Nokia 6 Disassembly, Nokia 6 Disassembly: 手順 1、 1の画像 1
    • Nokia 6 (TA-1011): after being in the water, the LEDs light up but the virtual keys (arrow, home and recent applications) do not work.
  2. Nokia 6 Disassembly: 手順 2、 3の画像 1 Nokia 6 Disassembly: 手順 2、 3の画像 2 Nokia 6 Disassembly: 手順 2、 3の画像 3
    • Take off the glass / display from its double-sided adhesive, heating the edges and lifting it with the aid of a suction cup and a thin piece of plastic (playing cards).
  3. Nokia 6 Disassembly: 手順 3、 2の画像 1 Nokia 6 Disassembly: 手順 3、 2の画像 2
    • Starting from the top (speaker area), gently lift the touch / display and disconnect the flat cable connector, unscrewing the screw and removing the plate that holds it in place.
    • At this point, using hot air if necessary, gently lift the flat to detach it from the underlying double-sided adhesive and remove the touch / display.
  4. Nokia 6 Disassembly: 手順 4、 2の画像 1 Nokia 6 Disassembly: 手順 4、 2の画像 2
    • Unscrew the screw, remove the plate and disconnect the virtual keys / fingerprint sensor cable.
    • Disassemble the "fingerprint sensor flex" module by uncoupling the flat cable from the double-sided tape
  5. Nokia 6 Disassembly: 手順 5、 3の画像 1 Nokia 6 Disassembly: 手順 5、 3の画像 2 Nokia 6 Disassembly: 手順 5、 3の画像 3
    • Unscrew the screws and unhook the metal plate, gently prizing it with a plastic tool.
    • Lift the metal plate sideways and disconnect the battery to be able to remove it
    • Metal plate with battery and speaker disassembled.
  6. Nokia 6 Disassembly: 手順 6、 1の画像 1
    • It can be seen, above the charging connector, that the humidity sensor is pink instead of white; this means that liquids have entered this area.
  7. Nokia 6 Disassembly: 手順 7、 3の画像 1 Nokia 6 Disassembly: 手順 7、 3の画像 2 Nokia 6 Disassembly: 手順 7、 3の画像 3
    • Unscrew the screws of the charging module and disconnect the antenna connector.
    • Insert trAfter uncoupling the flat cable from the underlying double-sided adhesive tape and removing the charging card, unscrew the screw and disconnect the flat cable.anslation here
    • Disassemble the top-up form.
  8. Nokia 6 Disassembly: 手順 8、 3の画像 1 Nokia 6 Disassembly: 手順 8、 3の画像 2 Nokia 6 Disassembly: 手順 8、 3の画像 3
    • After removing the sim / micro sd trolley with the extractor and disconnecting the antenna cable, headphone connector and volume / power buttons, unscrew the screws of the logic board.
    • Gently lift the motherboard by levering with a plastic tool and remove it from its seat.
    • Motherboard with the flat connection of the disassembled charging module
  9. Nokia 6 Disassembly: 手順 9、 1の画像 1
    • To check that there are no burnt components or oxidations inside the motherboard, the flex cable must be disconnected and the insulation / dissipation sheets of the various components of the logic board removed.
  10. Nokia 6 Disassembly: 手順 10、 1の画像 1
    • Looking closely at the microscope the part most exposed to water (as can be seen in step 6), small oxidations were found on the connection pins of the flat cable and the charging module that prevented communication with the motherboard of the sensor of fingerprints and virtual keys.
終わりに
To reassemble the device, follow these instructions in reverse order.
2 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
it en
100%
Lucy Smithさんは世界中で修理する私たちを助けてくれています! あなたも貢献してみませんか?
翻訳を始める ›
作成者
1人の作成者と共同作成されました。
MTM1011
メンバー登録日: 07/22/19
221 ポイント
1ガイドが承認済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 13
過去 30 日: 48
今までの合計 4,082
