メインコンテンツにスキップ
Nokia 5310b XpressMusic Motherboard Replacement
必要な工具と部品
  1. Nokia 5310b XpressMusic Motherboard Replacement, Battery: 手順 1、 1の画像 1
    • Slide the back cover down with your thumb.
    • *Note: the battery cover is not shown in this picture
  2. Nokia 5310b XpressMusic Motherboard Replacement: 手順 2、 2の画像 1 Nokia 5310b XpressMusic Motherboard Replacement: 手順 2、 2の画像 2
    • Gently lift the battery with a fingernail and remove it from its housing.
    • *Note: the battery may be replaced or repaired at this step
  3. Nokia 5310b XpressMusic Motherboard Replacement, Keypad: 手順 3、 3の画像 1 Nokia 5310b XpressMusic Motherboard Replacement, Keypad: 手順 3、 3の画像 2 Nokia 5310b XpressMusic Motherboard Replacement, Keypad: 手順 3、 3の画像 3
    • On some models, the front case is screwed down from the back. Follow steps 5 and 6 FIRST to remove the camera cover and two T6 screws, before removing the faceplate.
    • Use the Spudger to gently pry up the edges of the front face plate
    • At the center of the faceplate edge below the music keys there is a small latch on each side.
  4. Nokia 5310b XpressMusic Motherboard Replacement: 手順 4、 2の画像 1 Nokia 5310b XpressMusic Motherboard Replacement: 手順 4、 2の画像 2
    • Lift up the keypad from the bottom with either the spudger or your finger.
    • Note: at this time the keypad can be removed and replaced
  5. Nokia 5310b XpressMusic Motherboard Replacement, Motherboard: 手順 5、 1の画像 1
    • Gently unsnap the back camera cover from the phone.
    • Lift the cover from the phone after it is unsnapped.
  6. Nokia 5310b XpressMusic Motherboard Replacement: 手順 6、 2の画像 1 Nokia 5310b XpressMusic Motherboard Replacement: 手順 6、 2の画像 2
    • Use the T6 torx screwdriver head to remove the 2 screws on either side of the camera
    • Flip over the phone and again us the T6 torx head to remove the 4 screws located at each corner of the white keypad base
  7. Nokia 5310b XpressMusic Motherboard Replacement: 手順 7、 1の画像 1
    • Unclip the faceplate plug (ribbon) located in the lower left corner of the motherboard
  8. Nokia 5310b XpressMusic Motherboard Replacement: 手順 8、 2の画像 1 Nokia 5310b XpressMusic Motherboard Replacement: 手順 8、 2の画像 2
    • Use the Spudger to pry up the 2 metal clips located near the center of the motherboard on both the left and right
    • At this point the phone should come apart into 2 pieces, the motherboard/LCD screen and the faceplate
終わりに
4 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Max Kirby
メンバー登録日: 05/01/11
518 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 15-14, Regan Spring 2011 Cal Poly, Team 15-14, Regan Spring 2011人のメンバー
CPSU-REGAN-S11S15G14
3 メンバー
8のガイドは作成済み
コメント 1 件
Step 5 and 6 must be performed before step 3, otherwise, you will dislodge the thread from the front plate. so you have to remove the camera cover first, remove the 2 screws then you can remove the front plate without breaking anything.
Vincent Tschanz - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 13
今までの合計 6,977
