メインコンテンツにスキップ
Nokia 5165 Front Cover Replacement
必要な工具と部品
  1. Nokia 5165 Front Cover Replacement, Removing the Cover: 手順 1、 1の画像 1
    • Find the tab at the top of the phone and press down with your fingernail or the flat end of a spudger
  2. Nokia 5165 Front Cover Replacement: 手順 2、 3の画像 1 Nokia 5165 Front Cover Replacement: 手順 2、 3の画像 2 Nokia 5165 Front Cover Replacement: 手順 2、 3の画像 3
    • The top of the cover should pop out a little bit, pull the top of the cover out and the cover should come off
  3. Nokia 5165 Front Cover Replacement, Removing The Buttons: 手順 3、 3の画像 1 Nokia 5165 Front Cover Replacement, Removing The Buttons: 手順 3、 3の画像 2 Nokia 5165 Front Cover Replacement, Removing The Buttons: 手順 3、 3の画像 3
    • Pull off the number pad and store it some where safe, you'll need it for the new cover
    • Remove the power button with the flat end of a spudger by getting the spudger under the button and pulling it up by the red tabs
  4. Nokia 5165 Front Cover Replacement, Prepping The New Cover: 手順 4、 3の画像 1 Nokia 5165 Front Cover Replacement, Prepping The New Cover: 手順 4、 3の画像 2 Nokia 5165 Front Cover Replacement, Prepping The New Cover: 手順 4、 3の画像 3
    この手順で使用する道具:
    • Put the number pad into the new cover and push it down
    • For the power button, I recommend using blunt nose tweezers to put the button in with the slope on the top of the button going down towards the speaker hole, then using a spudger to push it in
    • Using pointed tweezers can put holes in the power button and possibly break the button, only use blunt nose tweezers
  5. Nokia 5165 Front Cover Replacement, Attacing The New Cover: 手順 5、 3の画像 1 Nokia 5165 Front Cover Replacement, Attacing The New Cover: 手順 5、 3の画像 2 Nokia 5165 Front Cover Replacement, Attacing The New Cover: 手順 5、 3の画像 3
    • Make sure the two tabs at the bottom of the cover go into the phone first at an angle, the push the top of the cover in until it clicks and then you are done!
終わりに
Now you have a new cover!
作成者
2人の作成者と共同で作成されました。
Ethan Pikscher
メンバー登録日: 12/19/18
351 ポイント
3のガイドは作成済み
チーム
Kid fixers Kid fixers人のメンバー
Community
187 メンバー
257のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 109
