はじめに
Use this guide to replace the front cover and the keypad of your Nokia 515
必要な工具と部品
Remove the back cover with your fingers or with the eject tool which is included by Nokia.
To remove the keypad, you should use the spudger to push the top clamps down a little bit while pressing your fingers against the inside of the keypad.
The keypad should be loose at the top.
To remove the bottom, just use a little bit of force to pull it off the front panel.
You did it!
You did it!
3 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
Leonさんは世界中で修理する私たちを助けてくれています! あなたも貢献してみませんか?
翻訳を始める ›
