メインコンテンツにスキップ
Nokia 3360 Charger Connector Replacement
必要な工具と部品
  1. Nokia 3360 Charger Connector Replacement, Battery: 手順 1、 1の画像 1
    • Press down on the back of the phone with your thumb. Then slide the back plate upward toward the top of the phone.
    • Lift the back plate off the phone.
  2. Nokia 3360 Charger Connector Replacement: 手順 2、 2の画像 1 Nokia 3360 Charger Connector Replacement: 手順 2、 2の画像 2
    • To release the battery, press the two tabs that are located directly above the battery towards the top of the phone at the same time.
  3. Nokia 3360 Charger Connector Replacement: 手順 3、 2の画像 1 Nokia 3360 Charger Connector Replacement: 手順 3、 2の画像 2
    • Lift the battery out of the phone.
    • Note: Upon reassembly of the phone refer to second picture. The bottom of the battery with three square openings should line up with the prongs sticking out of the phone.
  4. Nokia 3360 Charger Connector Replacement, Charger Connector: 手順 4、 2の画像 1 Nokia 3360 Charger Connector Replacement, Charger Connector: 手順 4、 2の画像 2
    • Use a pry tool towards the bottom of the phone to gently detach the face plate from the dark grey phone frame.
    • Hold phone frame down while separating the face plate.
    • Separate the faceplate and grey phone frame.
  5. Nokia 3360 Charger Connector Replacement: 手順 5、 2の画像 1 Nokia 3360 Charger Connector Replacement: 手順 5、 2の画像 2
    • Remove the six screws using a T6 screwdriver. (refer to second picture to help identify T6 screwdriver head).
    • NOTE: When reassembling the device be sure to not over tighten the screws.
  6. Nokia 3360 Charger Connector Replacement: 手順 6、 2の画像 1 Nokia 3360 Charger Connector Replacement: 手順 6、 2の画像 2
    • Place the phone with the screen facing down onto a flat surface.
    • Place the flat edge of the pry tool into the seam on the side, just above the screen. (refer to picture on where to place pry tool).
    • Push the pry tool into the seam.
    • Pry apart the plates until the cover separates from the rest of the phone. Be careful not to apply too much pressure
    • Proceed to pull the front cover away from the rest of the phone. (refer to second picture for results) The marking foreshadows what we will be using in the next step.
  7. Nokia 3360 Charger Connector Replacement: 手順 7、 3の画像 1 Nokia 3360 Charger Connector Replacement: 手順 7、 3の画像 2 Nokia 3360 Charger Connector Replacement: 手順 7、 3の画像 3
    • Locate the charger connector. (refer to picture with marker)
    • Carefully lift the charger connector upward to detach.
    • NOTE: When reassembling this device the charger connector is placed toward the bottom of the phone. The connector has a peg sticking out that fits into the logic board. (refer to third picture)
終わりに
ある他の人がこのガイドを完成しました。
作成者
9人の作成者と共同で作成されました。
Jonathan Phung
メンバー登録日: 01/26/10
15 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 8-39, Regan Winter 2010 Cal Poly, Team 8-39, Regan Winter 2010人のメンバー
CPSU-REGAN-W10S8G39
4 メンバー
15のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 10
今までの合計 5,295
