はじめに
If the frame of your Nokia 3310 3G is cracked or damaged, this guide will help you replace it.
必要な工具と部品
Using the thumbtab molded on the bottom of the phone, pry the back cover off using either a fingernail or a plastic opening tool.
Use a spudger to simultaneously leverage the shell away and the motherboard up from the body of the shell.
Using a metal spudger, lodge the tip underneath the speaker and between the soft foam surrounding the screen.
Use the metal spudger to leverage out the speaker.
7 の人々がこのガイドを完成させました。
