この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
This guide shows a step by step guide to fully access the keyboard, to clean it if it is sticking or completely replace the keypad if it is broken.
必要な工具と部品
Using the thumbtab molded on the bottom of the phone, pry the back cover off using either a fingernail or a plastic opening tool.
Use a spudger to simultaneously leverage the shell away and the motherboard up from the body of the shell.
Using a spudger, unclip the bottom left snap to unplug the keyboard. The image shows the motherboard rotated 90 degrees counterclockwise
5 の人々がこのガイドを完成させました。
