メインコンテンツにスキップ
Nokia 3300B Motherboard Replacement
必要な工具と部品
  1. Nokia 3300B Motherboard Replacement, Battery: 手順 1、 2の画像 1 Nokia 3300B Motherboard Replacement, Battery: 手順 1、 2の画像 2
    • Flip the Nokia 3300B over with the back-side facing towards you.
    • Gently press the button on the back of the battery cover to release the cover and slide up.
  2. Nokia 3300B Motherboard Replacement: 手順 2、 2の画像 1 Nokia 3300B Motherboard Replacement: 手順 2、 2の画像 2
    • Lift the battery out of the back of the phone.
    • It is easiest to lift the battery out of the phone from the right-hand side, as seen in the picture.
  3. Nokia 3300B Motherboard Replacement, Keyboard: 手順 3、 2の画像 1 Nokia 3300B Motherboard Replacement, Keyboard: 手順 3、 2の画像 2
    この手順で使用する道具:
    購入する
    • Gently push the blue tabs on the top of the phone out of their slots.
    • With the phone facing up, pop the blue faceplate off by using your fingernail (or some tweezers) and working your way around the phone.
    • Note: If the blue cover does not detach easily use your finger nails to try and split it open, as seen in the picture.
  4. Nokia 3300B Motherboard Replacement: 手順 4、 1の画像 1
    • With the screen still facing you, lift and remove the blue faceplate.
  5. Nokia 3300B Motherboard Replacement: 手順 5、 1の画像 1
    • Grab the sides of the keypad and lift each side up vertically, until the keypad is completely removed.
    • If you encounter resistance while removing the keypad, be sure to lift up evenly on both sides to ensure that the pins do not snap.
    • When replacing the keypad, make sure that the plastic pegs all enter their proper holes.
  6. Nokia 3300B Motherboard Replacement, Motherboard: 手順 6、 2の画像 1 Nokia 3300B Motherboard Replacement, Motherboard: 手順 6、 2の画像 2
    • Remove the six Torx T6 screws from the phone's front case.
  7. Nokia 3300B Motherboard Replacement: 手順 7、 1の画像 1
    • Pull up on the front case containing the screen to separate it from the rest of the phone.
    • Gently lift the main board out of the back case.
終わりに
3 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Jose Quezada
メンバー登録日: 04/13/10
50 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 18-65, Johann Spring 2010 Cal Poly, Team 18-65, Johann Spring 2010人のメンバー
CPSU-JOHANN-S10S18G65
4 メンバー
9のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 5
今までの合計 2,912
