この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
This guide directs the user to remove the battery of the Nokia 3120b. The battery is easily accessible as it is located directly under the back cover plate of the phone. A new battery can be installed the same way an old one is removed.
必要な工具と部品
Remove the back cover plate of the phone. To do this press down the lock as you slide the cover toward the bottom of the phone.
ある他の人がこのガイドを完成しました。
