はじめに
This guide will disassemble the phone's cover plate and key pad to reveal the interface in order to work on the phone's speaker. This guide requires a moderate amount of work as the small parts are tricky to remove.
必要な工具と部品
Remove the back cover plate of the phone. To do this press down the lock as you slide the cover toward the bottom of the phone.
Using your fingernails or another tool, pry the front face plate out along its edges and corners.
ある他の人がこのガイドを完成しました。
