はじめに
The LCD is difficult to get to and the guide requires a moderate amount of work. Tiny parts require patience during disassembly.
パーツ
パーツは必要ありません。
  1. Remove the back cover plate of the phone.  To do this press down the lock as you slide the cover toward the bottom of the phone. Remove the back cover plate of the phone.  To do this press down the lock as you slide the cover toward the bottom of the phone. Remove the back cover plate of the phone.  To do this press down the lock as you slide the cover toward the bottom of the phone.
    • Remove the back cover plate of the phone. To do this press down the lock as you slide the cover toward the bottom of the phone.
  2. Once the back cover plate is removed, the battery should be exposed. Remove the battery by prying it out.  This can be done with your finger-nail or a prying tool.
    • Once the back cover plate is removed, the battery should be exposed. Remove the battery by prying it out. This can be done with your finger-nail or a prying tool.
  3. Using your fingernails or another tool, pry the front face plate out along its edges and corners. Using your fingernails or another tool, pry the front face plate out along its edges and corners. Using your fingernails or another tool, pry the front face plate out along its edges and corners.
    • Using your fingernails or another tool, pry the front face plate out along its edges and corners.
  4. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  5. Once the cover plate has been removed, the keypad should easily pop out.
    • Once the cover plate has been removed, the keypad should easily pop out.
  6. Using a screwdriver, remove the 6, 7 mm Torx-head screws on the front of the phone. Using a screwdriver, remove the 6, 7 mm Torx-head screws on the front of the phone.
    • Using a screwdriver, remove the 6, 7 mm Torx-head screws on the front of the phone.
  7. Once the screws have been removed, the front plate of the phone should be removed, exposing the inside electronic components of the phone.
    • Once the screws have been removed, the front plate of the phone should be removed, exposing the inside electronic components of the phone.
  8. Take out the cell phone electronic board
    • Take out the cell phone electronic board
  9. The LCD screen can now be removed from the body of the phone.
    • The LCD screen can now be removed from the body of the phone.
まとめ
ある他の人がこのガイドを完成しました。
Pierre Tong
メンバー登録日: 2013年03月11日
53 ポイント
4のガイドは作成済み
チーム
Clemson, Team 13-2, Benson Spring 2013 Clemson, Team 13-2, Benson Spring 2013人のメンバー
CLEM-BENSON-S13S13G2
3 メンバー
14のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 6
今までの合計 974
