メインコンテンツにスキップ
Nokia 2630b Screen / Front Case Replacement
必要な工具と部品
  1. Nokia 2630b Screen / Front Case Replacement, Battery Case: 手順 1、 2の画像 1 Nokia 2630b Screen / Front Case Replacement, Battery Case: 手順 1、 2の画像 2
    • Press each release button on either side of the battery cover and simultaneously remove the battery cover from the phone.
  2. Nokia 2630b Screen / Front Case Replacement: 手順 2、 1の画像 1
    • Pull the battery out of the phone with your fingers.
  3. Nokia 2630b Screen / Front Case Replacement, Screen / Front Case: 手順 3、 1の画像 1
    • Remove the two screws on either side of the battery case using the microscrewdriver using the T5 bit
    • The T5 bit has a star shaped end and has "T5" engraved on the side of the bit for easy identification
    • NOTE: Keep the screws in a safe place while you continue working.
  4. Nokia 2630b Screen / Front Case Replacement: 手順 4、 3の画像 1 Nokia 2630b Screen / Front Case Replacement: 手順 4、 3の画像 2 Nokia 2630b Screen / Front Case Replacement: 手順 4、 3の画像 3
    • Separate the front case from the back case using the iPod opener
    • NOTE: The keypad is a loose piece and may fall out
  5. Nokia 2630b Screen / Front Case Replacement: 手順 5、 1の画像 1
    • Remove screws using the same T5 screw bit to release the computer chip from the case
  6. Nokia 2630b Screen / Front Case Replacement: 手順 6、 1の画像 1
    • Carefully lift the black frame off the screen with your fingers
  7. Nokia 2630b Screen / Front Case Replacement: 手順 7、 1の画像 1
    • Carefully remove the computer chip and screen out of the black case with your fingers
  8. Nokia 2630b Screen / Front Case Replacement: 手順 8、 2の画像 1 Nokia 2630b Screen / Front Case Replacement: 手順 8、 2の画像 2
    • The screen is attached to the motherboard by an orange ribbon
    • Carefully detach the ribbon from the motherboard using your fingers
  9. Nokia 2630b Screen / Front Case Replacement: 手順 9、 1の画像 1
    • Reattach new screen by connecting the orange ribbon to the computer chip
  10. Nokia 2630b Screen / Front Case Replacement: 手順 10、 2の画像 1 Nokia 2630b Screen / Front Case Replacement: 手順 10、 2の画像 2
    • Place computer chip and screen back into black case
  11. Nokia 2630b Screen / Front Case Replacement: 手順 11、 1の画像 1
    • Place black frame back over screen
  12. Nokia 2630b Screen / Front Case Replacement: 手順 12、 2の画像 1 Nokia 2630b Screen / Front Case Replacement: 手順 12、 2の画像 2
    • Carefully place keypad back in place
  13. Nokia 2630b Screen / Front Case Replacement: 手順 13、 2の画像 1 Nokia 2630b Screen / Front Case Replacement: 手順 13、 2の画像 2
    • Snap the front case back in place with the bottom case with your fingers
  14. Nokia 2630b Screen / Front Case Replacement: 手順 14、 1の画像 1
    • Reassemble screws with microscrewdriver
  15. Nokia 2630b Screen / Front Case Replacement: 手順 15、 1の画像 1
    • Slide battery back into place
  16. Nokia 2630b Screen / Front Case Replacement: 手順 16、 1の画像 1
    • Snap battery cover back into place
終わりに
To reassemble your device, follow these instructions in reverse order. Make sure to snap the new screen / front case securely into place.
作成者
11人の作成者と共同で作成されました。
Eric
メンバー登録日: 04/07/11
51 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 9-61, Walters Spring 2011 Cal Poly, Team 9-61, Walters Spring 2011人のメンバー
CPSU-WALTERS-S11S9G61
5 メンバー
5のガイドは作成済み
2 件のコメント
Great guide :-) I have a Nokia 2630 too and people can no longer hear me on calls, even though I can hear them. Do you know what could be wrong? Do you think this is something I could fix myself? Thanks!
jfg - 返信
You could try getting a neodymium magnet and run it across the earpiece grill. In my father's case, a lot of metal powder was in there, pressing in the speaker membrane; the alternative is cleaning it (which does require opening the phone using Eric's very nice guide). The alternative to those is ordering an earpiece online - but usually those are really bad quality, so trying to fix the original one would be advisable
Darie H -
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 15
今までの合計 3,810
