このバージョンは誤った内容を含んでいる可能性があります。最新の承認済みスナップショットに切り替えてください。
必要な工具と部品
この手順は未翻訳です。 翻訳を手伝う。
The antenna is the "L" shaped device located on the top of the phone in between the back case and the board.
You should be able to remove the antenna with minimal effort.
To put in a new antenna, place it in the same location as the old one. There is no need to connect to any hardware on the phone.
この手順は未翻訳です。 翻訳を手伝う。
To reassemble the device, follow the instructions in reverse order.
When reinstalling the keyboard, make sure it is in the correct position before screwing the case back together.
When reinstalling the battery, make sure the contacts of the battery connect to the contacts on the phone.
The red square in the photo indicates the position of the brass contacts of the battery.
The photo displays the correct orientation of the battery.
