メインコンテンツにスキップ
Nokia 2610 Circuit Board Replacement
必要な工具と部品
  1. Nokia 2610 Circuit Board Replacement, Battery and Sim Card: 手順 1、 3の画像 1 Nokia 2610 Circuit Board Replacement, Battery and Sim Card: 手順 1、 3の画像 2 Nokia 2610 Circuit Board Replacement, Battery and Sim Card: 手順 1、 3の画像 3
    • Place your thumb on the middle of the back cover and push it toward the bottom of the phone to slide the cover off.
  2. Nokia 2610 Circuit Board Replacement: 手順 2、 3の画像 1 Nokia 2610 Circuit Board Replacement: 手順 2、 3の画像 2 Nokia 2610 Circuit Board Replacement: 手順 2、 3の画像 3
    • Use a plastic opening tool (or your finger) to gently pry the battery out of the battery slot on the back of the phone.
  3. Nokia 2610 Circuit Board Replacement: 手順 3、 3の画像 1 Nokia 2610 Circuit Board Replacement: 手順 3、 3の画像 2 Nokia 2610 Circuit Board Replacement: 手順 3、 3の画像 3
    • Lift the metal sim card holder (at the bottom of the battery slot) up and carefully pry the sim card out of its slot with a plastic opening tool or your finger.
    • After removal, lower the metal sim card holder into its original position.
  4. Nokia 2610 Circuit Board Replacement, Front Pannel: 手順 4、 2の画像 1 Nokia 2610 Circuit Board Replacement, Front Pannel: 手順 4、 2の画像 2
    • Insert the plastic opening tool into the crack between the front and back panels.
    • Gently pry the front cover away from the back cover while sliding the plastic opening tool towards the top of the phone.
  5. Nokia 2610 Circuit Board Replacement: 手順 5、 2の画像 1 Nokia 2610 Circuit Board Replacement: 手順 5、 2の画像 2
    • Lift the bottom of the front cover away from the phone.
    • Continue lifting until the top of the front cover is fully removed from the phone.
    • Note: To replace the Keypad, gently lift it out of the front cover. It is located below the clear viewing window.
  6. Nokia 2610 Circuit Board Replacement, Circuit Board: 手順 6、 1の画像 1
    • Use the Torx screwdriver with the T6 attachmet to remove the 6 .4 mm screws around the outside of the circuit board.
    • Note: Removing the 4 T6 screws around the screen will loosen it, so don't worry if the screen also separates from the circuit board.
  7. Nokia 2610 Circuit Board Replacement: 手順 7、 3の画像 1 Nokia 2610 Circuit Board Replacement: 手順 7、 3の画像 2 Nokia 2610 Circuit Board Replacement: 手順 7、 3の画像 3
    • Lift the circuit board out of the back cover.
終わりに
5 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Andrew Wood
メンバー登録日: 10/05/10
336 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 7-52, Amido Fall 2010 Cal Poly, Team 7-52, Amido Fall 2010人のメンバー
CPSU-AMIDO-F10S7G52
4 メンバー
12のガイドは作成済み
コメント 1 件
This is so cool tom!
Mo Chiggle - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 3,235
