はじめに
The time on your phone is always wrong, making you arrive at the wrong time. Switch out the internal clock battery and always be on time.
必要な工具と部品
Be sure cell phone is off before you begin to disassemble the phone.
Press the button on the bottom of the back of the cell phone.
Slide rear panel down and remove it.
Insert the plastic opening tool under the faceplate.
Separate the faceplate from main body by twisting the prying tool with some force.
The faceplate is held by three plastic fasteners, so pry evenly on both sides of phone.
Locate and remove the six screws on the front of the phone using a T6 Torx.
All 6 screws are 6.9mm long.
With the logic board completely removed, gently pry out the internal clock battery from its housing.
ある他の人がこのガイドを完成しました。
