メインコンテンツにスキップ
はじめに
Removing the front and back case will allow you access to other parts of this device.
パーツ
パーツは指定されていません。
  1. Turn over the device so that the back of the device is facing up.
    • Turn over the device so that the back of the device is facing up.
  2. Insert the first plastic opening tool along the side to pry open the case. Sliding the plastic opening tool, while inserted, along the seam may help the removal process. Use a second plastic opening tool to help separate the remaining seams.
    • Insert the first plastic opening tool along the side to pry open the case.
    • Sliding the plastic opening tool, while inserted, along the seam may help the removal process.
    • Use a second plastic opening tool to help separate the remaining seams.
  3. There is a long strip of double sided adhesive foam tape that prevents the back case from easily being removed. Pull the back case off by applying steady pressure to remove it from the adhesive foam tape.
    • There is a long strip of double sided adhesive foam tape that prevents the back case from easily being removed.
    • Pull the back case off by applying steady pressure to remove it from the adhesive foam tape.
  4. Use the Phillips precision screwdriver to unscrew the two 5.0 mm Phillips screws from the circuit board. Remove the solar panel and circuit board from the front case.
    • Use the Phillips precision screwdriver to unscrew the two 5.0 mm Phillips screws from the circuit board.
    • Remove the solar panel and circuit board from the front case.
終わりに
ある他の人がこのガイドを完成しました。
Jeremy
メンバー登録日: 2015年01月21日
157 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 9-3, Blackwell Winter 2015 USF Tampa, Team 9-3, Blackwell Winter 2015人のメンバー
USFT-BLACKWELL-W15S9G3
3 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 124
