はじめに
If pushing the power switch up to the on direction, you may need to use this guide to replace the power switch.
必要な工具と部品
Press down firmly to remove the battery cover and display battery.
Then remove the battery.
Place the plastic opening tool in between the two plastic panels and slowly work your way around the device.
Unlatch the clips on the inside and pull device apart.
もう少しです!
終わりに
