はじめに
If the suction cup no longer sticks to surfaces or if the plastic has split, you will need to replace the suction cup with a new one.
必要な工具と部品
Press down firmly to remove the battery cover and display battery.
Then remove the battery.
Place the plastic opening tool in between the two plastic panels and slowly work your way around the device.
Unlatch the clips on the inside and pull device apart.
もう少しです!
終わりに
