このバージョンは誤った内容を含んでいる可能性があります。最新の承認済みスナップショットに切り替えてください。
必要な工具と部品
ある他の人がこのガイドを完成しました。
8 件のコメント
Where can I buy a gasket, for the Recovery Pro massager, that is worn out? Thank you.
RecoveryPRO Support https://recoverypro.com.au/products/rp2-...
jtalbin -
We were unable to twist off the back on Step 2. Going to be returned to Costco since I can't fix it....
I have model 11mg0811 it has no screws on the sides and I it will not twist off ,when it's on it makes a lot of noise,I don't want to return it to COSTCO IS THERE SOMEWHERE I CAN TAKE IT,
I've not found any shops locally that take these for repair. After looking at the pictures for the model 11MG0811 it appears that access to the inner workings is similar to an electronic toothbrush that uses a pinch/lock approach which can be quite a bit tougher.
jtalbin -
