メインコンテンツにスキップ
Noisy Percussion Massager Repair
必要な工具と部品
  1. Noisy Percussion Massager Repair, Tools - #1 & #2 Phillips + thread locker: 手順 1、 1の画像 1
    • Thread lock can be found at any hardware store.
  2. Noisy Percussion Massager Repair, Remove the rear cover: 手順 2、 2の画像 1 Noisy Percussion Massager Repair, Remove the rear cover: 手順 2、 2の画像 2
    • Twist counter-clockwise very snug. It only moves about 1/4 of an inch - the second picture shows the slide lock slots.
  3. Noisy Percussion Massager Repair, Remove Two Screws from Housing: 手順 3、 1の画像 1
    • There were actually two rubber plugs covering the screws that I had to work out… Not hard.
  4. Noisy Percussion Massager Repair, Open It Up: 手順 4、 3の画像 1 Noisy Percussion Massager Repair, Open It Up: 手順 4、 3の画像 2 Noisy Percussion Massager Repair, Open It Up: 手順 4、 3の画像 3
    • Case opens pretty easy but you can see there are two tabs toward the back of the case … if it sticks, a simple pinch might help you open it up.
  5. Noisy Percussion Massager Repair, Remove screw - Apply Thread Lock - Re install: 手順 5、 3の画像 1 Noisy Percussion Massager Repair, Remove screw - Apply Thread Lock - Re install: 手順 5、 3の画像 2 Noisy Percussion Massager Repair, Remove screw - Apply Thread Lock - Re install: 手順 5、 3の画像 3
    • Insert wisdom here.
  6. Noisy Percussion Massager Repair, Re-assemble the case: 手順 6、 2の画像 1 Noisy Percussion Massager Repair, Re-assemble the case: 手順 6、 2の画像 2
    • Surprising how much noise a loose screw can cause.
終わりに
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
jtalbin
メンバー登録日: 07/22/12
313 ポイント
2のガイドは作成済み
8 件のコメント
Where can I buy a gasket, for the Recovery Pro massager, that is worn out? Thank you.
Emilia Cirstea - 返信
We were unable to twist off the back on Step 2. Going to be returned to Costco since I can't fix it....
Richard DalCanto - 返信
I have model 11mg0811 it has no screws on the sides and I it will not twist off ,when it's on it makes a lot of noise,I don't want to return it to COSTCO IS THERE SOMEWHERE I CAN TAKE IT,
Ted - 返信
I've not found any shops locally that take these for repair. After looking at the pictures for the model 11MG0811 it appears that access to the inner workings is similar to an electronic toothbrush that uses a pinch/lock approach which can be quite a bit tougher.
jtalbin -
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 40
過去 30 日: 211
今までの合計 9,718
