はじめに
To complete this guide, you will need to disassemble your tablet and use a soldering iron to replace the battery. The battery is removed first in most cases, even if you are trying to remove other components.
必要な工具と部品
Look towards the topside of the tablet, where the power button is located.
Insert a plastic opening tool in the crack between the two parts of the case.
Move it gently back and forth to open the case.
3 の人々がこのガイドを完成させました。
コメント 1 件
where do you find that battery? tried searching by the numbers on it and nothing
