メインコンテンツにスキップ
Nishiki Aero II Tire Removal
必要な工具と部品
  1. Nishiki Aero II Tire Removal, Removing Road Bike Front Wheel: 手順 1、 1の画像 1
    • Turn the bike upside down.
  2. Nishiki Aero II Tire Removal: 手順 2、 1の画像 1
    • Use a wrench to loosen the nut holding the wheel's axle on one side.
    • Once it's loose enough, continue removing the nut with your hand.
  3. Nishiki Aero II Tire Removal: 手順 3、 2の画像 1 Nishiki Aero II Tire Removal: 手順 3、 2の画像 2
    • After removing the nut, also remove the washer under it.
    • Keep note of how the washer has a small appendage that locks into a slot in the fork.
  4. Nishiki Aero II Tire Removal: 手順 4、 1の画像 1
    • Follow the previous steps for the opposite side.
  5. Nishiki Aero II Tire Removal: 手順 5、 1の画像 1
    • Lift the wheel up from the fork.
  6. Nishiki Aero II Tire Removal, Nishiki Aero II Tire Removal: 手順 6、 2の画像 1 Nishiki Aero II Tire Removal, Nishiki Aero II Tire Removal: 手順 6、 2の画像 2
    • Unscrew the cap from the air valve.
    • Release the tire's air by pressing a thin object on the center pin of the valve.
    • A hex wrench or any blunt object can be used.
  7. Nishiki Aero II Tire Removal: 手順 7、 3の画像 1 Nishiki Aero II Tire Removal: 手順 7、 3の画像 2 Nishiki Aero II Tire Removal: 手順 7、 3の画像 3
    • Wedge a tire lever between the tire and the rim. Grab the tire with the lever's inward scoop.
    • Grab the tire's edge with the lever and pull it back to scoop the tire from the rim.
    • Keep the tire lever anchored on a spoke with the notch on the lever's opposite end.
  8. Nishiki Aero II Tire Removal: 手順 8、 2の画像 1 Nishiki Aero II Tire Removal: 手順 8、 2の画像 2
    • Repeat with an additional tire lever five inches away from the other.
  9. Nishiki Aero II Tire Removal: 手順 9、 3の画像 1 Nishiki Aero II Tire Removal: 手順 9、 3の画像 2 Nishiki Aero II Tire Removal: 手順 9、 3の画像 3
    • Repeat with a third tire lever farther around the tire.
    • Alternate lifting the second and third levers until the tire comes partway off.
  10. Nishiki Aero II Tire Removal: 手順 10、 3の画像 1 Nishiki Aero II Tire Removal: 手順 10、 3の画像 2 Nishiki Aero II Tire Removal: 手順 10、 3の画像 3
    • Wedge the tire off of the other rim with the tire levers.
    • Pull the air valve from its hole in the rim to completely remove the tire.
終わりに
作成者
8人の作成者と共同で作成されました。
Tobias Elder
メンバー登録日: 04/25/13
113 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 21-53, Johann Spring 2013 Cal Poly, Team 21-53, Johann Spring 2013人のメンバー
CPSU-JOHANN-S13S21G53
4 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 8
過去 30 日: 16
今までの合計 1,221
