はじめに
Use this guide to replace the two antennas responsible for providing Wi-Fi connectivity.
必要な工具と部品
Use a metal spudger to remove the white plastic screw covers stuck to the lower case near the front of the Wii.
Open the controller port cover until it is perpendicular to the black controller port bezel.
Pull the controller port cover straight up to release it from the outer case.
Remove the small Phillips screw securing the battery door to the bottom panel.
Pull the battery door out of the Wii.
Use a pair of tweezers to lift the fan connector up and out of its socket on the logic board.
Lift the side of the Wi-Fi board furthest away from the heat sink and lift it out of its socket on the motherboard, being careful not to put too much sideways force on the connector.
5 の人々がこのガイドを完成させました。
