はじめに
Use this guide to replace the two antennas responsible for providing Wi-Fi connectivity.
  1. Use a metal spudger to remove the white plastic screw covers stuck to the lower case near the front of the Wii.
    • Use a metal spudger to remove the white plastic screw covers stuck to the lower case near the front of the Wii.
  2. Remove the two 8.3 mm Tri-Wing screws hidden under the covers you just removed.
    • Remove the two 8.3 mm Tri-Wing screws hidden under the covers you just removed.
    • Remove the single 5.9 mm Phillips screw under the controller port door nearest the faceplate.
    • Use a metal spudger to remove the rubber foot stuck to the side of the Wii near the DVD drive opening.
    • Remove the single 5.9 mm Phillips screw hidden under the foot you just removed.
    • Carefully pull the faceplate away from the front of the Wii.
    • Use a pair of tweezers to disconnect the LED cable's plastic connector from the motherboard.
    • Remove the faceplate.
    • Open the controller port cover until it is perpendicular to the black controller port bezel.
    • Pull the controller port cover straight up to release it from the outer case.
    • Repeat this procedure for the memory card port cover.
    • Remove the two remaining 4.1 mm Phillips screws along the top edge of the black plastic controller port bezel.
    • Lift the bezel from the long edge furthest away from the controller ports and remove it from the Wii.
    • Remove the two 5 mm Phillips screws above the controller ports.
    • Use a metal spudger to remove the three highlighted screw covers stuck to the side of the Wii.
    • Remove the following screws:
      • Two 5 mm Phillips screws
      • One 8.2 mm Tri-Wing screw
    • Use a metal spudger to remove the two rubber feet stuck to the bottom face of the Wii near the rear ports.
    • Remove the two 8.2 mm Tri-Wing screws hidden under the feet you just removed.
    • Lift the outer case straight up off the body of the Wii.
    • Remove the small Phillips screw securing the battery door to the bottom panel.
    • This screw is captive to the battery door.
    • Pull the battery door out of the Wii.
    • This is a good time to change the CR2032 battery if it hasn't been changed recently.
    • Remove the 8.2 mm Tri-Wing screw that was hidden beneath the battery door.
    • Remove the two 8.2 mm Tri-Wing screws securing the DVD drive shield near the controller ports.
    • Lift the DVD drive shield upward and remove it from the Wii.
    • Remove the four 9 mm Phillips screws securing the DVD drive to the bottom panel.
    • Lift the side of the DVD drive opposite the controller ports enough to access the cables on its bottom face.
    • Carefully pull the DVD drive power cable out from under the plastic shroud near the heat sink.
    • Pull the DVD drive power cable away from its socket on the DVD drive.
    • Use your fingernail to flip up the retaining flap on the DVD drive ribbon cable socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • Pull the DVD drive ribbon cable out of its socket.
    • Remove the DVD drive from the Wii.
    • Use a pair of tweezers to lift the fan connector up and out of its socket on the logic board.
    • Be sure your tweezers are clamped down on the fan connector, not the socket on the motherboard.
    • Remove the two 10 mm Phillips screws securing the fan to the fan shroud.
    • Remove the fan from the Wii.
    • Use the tip of a spudger or another fine-pointed tool to carefully pry one of the black plastic retaining fingers attached to the fan shroud away from the Wi-Fi antenna board.
    • Lift the Wi-Fi antenna out of the fan shroud.
    • Remove the single 10 mm Phillips screw securing the second Wi-Fi antenna to the top of the fan shroud.
    • Remove the two pieces of tape securing the second Wi-Fi antenna cable to the plastic bracket near the heat sink.
    • Carefully de-route both antennas from the frame of the Wii and lay them aside.
    • Remove the three 10 mm Phillips screws securing the fan shroud to the Wii.
    • Lift the fan shroud off the heat sink and remove it from the Wii.
    • Remove the following six screws securing the EMI fingers to the bottom panel:
      • Four 7 mm Phillips screws
      • Two 11.3 mm Phillips screws
    • Remove both sets of EMI fingers from the Wii.
    • Remove the following three screws:
      • One 7 mm Phillips screw
      • Two 10 mm Phillips screws
    • Lift the bracket out of the Wii.
    • Remove the three 10 mm Phillips screws securing the black bracket to the bottom panel near the front of the Wii.
    • Slightly lift the bracket and use your other hand to pull the retaining clip away from where the Wi-Fi antennas enter the motherboard sheild.
    • Remove the bracket from the Wii.
    • Be sure not to lose the small square nut loosely held by the black plastic bracket.
    • Remove the nine remaining 7 mm Phillips screws securing the motherboard cover to the bottom panel.
    • Carefully lift the motherboard cover off the motherboard, minding any cables that may get caught.
    • Lift the side of the Wi-Fi board furthest away from the heat sink and lift it out of its socket on the motherboard, being careful not to put too much sideways force on the connector.
    • Use the flat end of a spudger to pry both antenna connectors off their sockets on the Wi-Fi board.
まとめ
4 の人々がこのガイドを完成させました。
Andrew Bookholt
505,724 ポイント
618のガイドは作成済み
コメント1件
After I pry the antenna's off then what
Brendan keller - 返信
統計データを表示:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 37
今までの合計 10,134
