メインコンテンツにスキップ
Nintendo Wii U Pro Controller ZL and ZR Button Replacement
必要な工具と部品
  1. Nintendo Wii U Pro Controller ZL and ZR Button Replacement, Battery: 手順 1、 1の画像 1
    • Turn the controller over to reveal the battery cover.
    • Use the J000 screwdriver to remove the screw that secures the battery cover.
  2. Nintendo Wii U Pro Controller ZL and ZR Button Replacement: 手順 2、 2の画像 1 Nintendo Wii U Pro Controller ZL and ZR Button Replacement: 手順 2、 2の画像 2
    • Remove the battery from the controller by inserting the plastic spudger into the small gap on the bottom right of the battery.
    • Use the spudger as a lever to pry up and remove the battery from the compartment.
  3. Nintendo Wii U Pro Controller ZL and ZR Button Replacement, ZL and ZR Buttons: 手順 3、 1の画像 1
    • Once the battery has been removed, we will remove the 4 screws in the battery compartment and then the 4 screws around the back of the case. These 8 screws use the Y0 bit. Each of these screws are 5.5 mm.
    • The four screws on the outside are extremely deep into the casing, and the holes are pretty small. You will need to use a 4 mm driver bit extension to reach these screws.
  4. Nintendo Wii U Pro Controller ZL and ZR Button Replacement: 手順 4、 1の画像 1
    • Once all of the screws are removed, simply use one hand to hold the front panel in place and lift up on the back panel to remove it. Place the back panel so the insides are facing up towards you.
  5. Nintendo Wii U Pro Controller ZL and ZR Button Replacement: 手順 5、 2の画像 1 Nintendo Wii U Pro Controller ZL and ZR Button Replacement: 手順 5、 2の画像 2
    • Locate the two triggers (ZL and ZR) and pop them up and out by pressing on them from the outside.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Jesse Burton
メンバー登録日: 09/17/15
586 ポイント
3のガイドは作成済み
チーム
IUPUI, Team 2-2, Harley Fall 2015 IUPUI, Team 2-2, Harley Fall 2015人のメンバー
IUPUI-HARLEY-F15S2G2
4 メンバー
15のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 5
過去 30 日: 27
今までの合計 4,710
