メインコンテンツにスキップ
Nintendo Wii U Pro Controller D-Pad Replacement
必要な工具と部品
  1. Nintendo Wii U Pro Controller D-Pad Replacement, Battery: 手順 1、 1の画像 1
    • Turn the controller over to reveal the battery cover.
    • Use the J000 screwdriver to remove the screw that secures the battery cover.
  2. Nintendo Wii U Pro Controller D-Pad Replacement: 手順 2、 2の画像 1 Nintendo Wii U Pro Controller D-Pad Replacement: 手順 2、 2の画像 2
    • Remove the battery from the controller by inserting the plastic spudger into the small gap on the bottom right of the battery.
    • Use the spudger as a lever to pry up and remove the battery from the compartment.
  3. Nintendo Wii U Pro Controller D-Pad Replacement, Joystick: 手順 3、 1の画像 1
    • Remove the eight 5.5 mm Y0 screws.
  4. Nintendo Wii U Pro Controller D-Pad Replacement: 手順 4、 2の画像 1 Nintendo Wii U Pro Controller D-Pad Replacement: 手順 4、 2の画像 2
    • Now that you have removed all of the screws, carefully separate and remove the bottom half of the controller shell from the top half.
    • If you feel any resistance when pulling the shells apart, use a spudger to separate the left and right trigger contact assemblies from the bottom shell.
  5. Nintendo Wii U Pro Controller D-Pad Replacement: 手順 5、 1の画像 1
    • Move the right trigger and sensor out of the way.
    • Remove the 4 mm JIS #0 screw.
  6. Nintendo Wii U Pro Controller D-Pad Replacement: 手順 6、 1の画像 1
    • Move the left trigger and sensor out of the way.
  7. Nintendo Wii U Pro Controller D-Pad Replacement: 手順 7、 1の画像 1
    • Remove the joysticks and motherboard from the controller’s shell.
  8. Nintendo Wii U Pro Controller D-Pad Replacement: 手順 8、 1の画像 1
    • Carefully pull the rubber thumbsticks off of the electronic bearings to remove the joysticks.
  9. Nintendo Wii U Pro Controller D-Pad Replacement, D-Pad: 手順 9、 1の画像 1
    • Locate the two 4 mm motherboard screws, shown circled in red, with the J0 screwdriver.
  10. Nintendo Wii U Pro Controller D-Pad Replacement: 手順 10、 1の画像 1
    • Remove the motherboard and connected components. The rubber pad of the D-Pad is indicated in the image by the red arrow.
  11. Nintendo Wii U Pro Controller D-Pad Replacement: 手順 11、 1の画像 1
    • Remove the rubber pad and D-Pad button. The D-Pad can be replaced by the new D-Pad or be cleaned to improve condition.
終わりに
3 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Jesse Burton
メンバー登録日: 09/17/15
586 ポイント
3のガイドは作成済み
チーム
IUPUI, Team 2-2, Harley Fall 2015 IUPUI, Team 2-2, Harley Fall 2015人のメンバー
IUPUI-HARLEY-F15S2G2
4 メンバー
15のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 14
過去 30 日: 42
今までの合計 4,443
