メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
はじめに
The motherboard is an essential, key component that gaming consoles revolve around. If troubleshooting does not help your Wii U and you are in need of a motherboard replacement, this guide will easily walk you through the process.
  1. With the bottom of the console facing up, remove the following 6 screws hidden underneath the white square stickers:
    • With the bottom of the console facing up, remove the following 6 screws hidden underneath the white square stickers:
    • Three 5.1mm Phillips #000 screws
    • Two 6.1mm Tri-wing Y0 screws
    • One 13.2mm Tri-wing Y1 screw
  2. Rotate the console 180 degrees so that the exhaust vents are facing you.
    • Rotate the console 180 degrees so that the exhaust vents are facing you.
    • Remove the two 7.1mm Phillips #00 screws.
  3. On the side opposite of the exhaust vents, slide the cover faceplate towards the back of the console and pull upwards to release it. On the side opposite of the exhaust vents, slide the cover faceplate towards the back of the console and pull upwards to release it.
    • On the side opposite of the exhaust vents, slide the cover faceplate towards the back of the console and pull upwards to release it.
  4. On the bottom of the console beneath the previously removed faceplate, remove the three 13.2mm Tri-wing Y1 screws.
    • On the bottom of the console beneath the previously removed faceplate, remove the three 13.2mm Tri-wing Y1 screws.
  5. On the back of the console, lift up and release the main top cover. On the back of the console, lift up and release the main top cover. On the back of the console, lift up and release the main top cover.
    • On the back of the console, lift up and release the main top cover.
  6. Rotate the device so that the front plate is facing you. On each side of the console, remove the 3.5mm Phillips #0 screw connecting the DVD drive to the faceplate.
    • Rotate the device so that the front plate is facing you.
    • On each side of the console, remove the 3.5mm Phillips #0 screw connecting the DVD drive to the faceplate.
  7. Rotate the device so that the front plate is on the right side and the ribbon cable is visible.
    • Rotate the device so that the front plate is on the right side and the ribbon cable is visible.
    • Lift up on the blue tab to release the ribbon cable.
  8. Remove the front faceplate.
    • Remove the front faceplate.
  9. On each side of the DVD drive, remove the two 4.6mm Phillips #0 mounting screws.
    • On each side of the DVD drive, remove the two 4.6mm Phillips #0 mounting screws.
  10. Rotate the device so that the DVD slot is visible. A ribbon cable is attached to the bottom right side of the DVD drive. The ribbon cable can rip if it isn't removed properly.
    • Rotate the device so that the DVD slot is visible.
    • A ribbon cable is attached to the bottom right side of the DVD drive. The ribbon cable can rip if it isn't removed properly.
    • Lift the DVD drive out of the mount and turn over to the right so it lies like a book.
    • Use a spudger to release the ribbon cable.
  11. Remove the CD drive.
    • Remove the CD drive.
  12. Remove the black plastic shielding by unscrewing connecting screws with a Phillip's Head screwdriver. You will have to carefully adjust the antenna cables out of the way in order to proceed comfortably. You will have to carefully adjust the antenna cables out of the way in order to proceed comfortably.
    • Remove the black plastic shielding by unscrewing connecting screws with a Phillip's Head screwdriver.
    • You will have to carefully adjust the antenna cables out of the way in order to proceed comfortably.
  13. The metal cap does not require unscrewing and should lift up with ease. Unscrew all the screws that outline the perimeter of the board using a Phillips Head (PH1) screwdriver. Remove the silver shielding plate once all screws are removed. Be careful when pulling it under the affixed antenna cables.
    • The metal cap does not require unscrewing and should lift up with ease.
    • Unscrew all the screws that outline the perimeter of the board using a Phillips Head (PH1) screwdriver.
    • Remove the silver shielding plate once all screws are removed. Be careful when pulling it under the affixed antenna cables.
  14. At this point, the motherboard should easily separate from the lower tray. At this point, the motherboard should easily separate from the lower tray.
    • At this point, the motherboard should easily separate from the lower tray.
終わりに
6 の人々がこのガイドを完成させました。
Emily Vasquez
メンバー登録日: 2016年02月24日
675 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team 1-2, Leahy Spring 2016 USF Tampa, Team 1-2, Leahy Spring 2016人のメンバー
USFT-LEAHY-S16S1G2
3 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 5
過去 7 日: 28
過去 30 日: 111
今までの合計 7,407
