メインコンテンツにスキップ
Nintendo Wii U GamePad Directional Pad Buttons Replacement
必要な工具と部品
  1. Nintendo Wii U GamePad Directional Pad Buttons Replacement, Outer Case: 手順 1、 3の画像 1 Nintendo Wii U GamePad Directional Pad Buttons Replacement, Outer Case: 手順 1、 3の画像 2 Nintendo Wii U GamePad Directional Pad Buttons Replacement, Outer Case: 手順 1、 3の画像 3
    • Remove the ten 8.9mm Tri-wing Y1 screws hidden underneath square stickers.
    • Lift up the back plate.
    • The back plate is still connected by a cable to the motherboard.
    how do i replace the whole front and back casing?
    enbodylin - 返信
    bruh the ifix it screwdriver dont reach down the whole way
    Michael - 返信
    I feel like it’s important to mention how deep some of these holes are. Your screwdriver might not reach. Mine sure didn’t.
    greatshadowdude - 返信
    I had to shove some tissue into the screwdriver bit holder to get it to reach
    Andrew Walker - 返信
  2. Nintendo Wii U GamePad Directional Pad Buttons Replacement: 手順 2、 2の画像 1 Nintendo Wii U GamePad Directional Pad Buttons Replacement: 手順 2、 2の画像 2
    • Unplug the connector that connects the back plate to the motherboard.
    • Remove the back plate.
    You don't have to remove just be careful
    Heather Sheppard - 返信
    I tried to remove like at least 6 times but I wasn’t able to. Using tweezer, my nails, long nose pliers. There could be a lock but I gave up since I’m afraid if I put more force I might accidentally pull the wires. I’m able to remove the left and right analog stick with the back plate plugged, as mentioned, just be careful.
    Royce Remulla - 返信
    I was stuck on this step for a while - note that you’re only removing the little white plastic bit. The beige or yellowish plastic bit is attached to the board. I needed to use pliers to carefully grab just the white plastic bit and wiggle it side to side.
    Nova H - 返信
  3. Nintendo Wii U GamePad Directional Pad Buttons Replacement, Analog Stick: 手順 3、 2の画像 1 Nintendo Wii U GamePad Directional Pad Buttons Replacement, Analog Stick: 手順 3、 2の画像 2
    • Take out the left and right shoulder buttons in the upper corners.
    • Remove the ZR and ZL trigger buttons by lifting up and sliding outward.
  4. Nintendo Wii U GamePad Directional Pad Buttons Replacement: 手順 4、 2の画像 1 Nintendo Wii U GamePad Directional Pad Buttons Replacement: 手順 4、 2の画像 2
    • Remove the top rubber cover by pulling it off of its mounts to access one of the mounting screws.
    • Remove the four 5.2mm Phillips #0 screws.
  5. Nintendo Wii U GamePad Directional Pad Buttons Replacement: 手順 5、 2の画像 1 Nintendo Wii U GamePad Directional Pad Buttons Replacement: 手順 5、 2の画像 2
    • Use a spudger to lift the tab which releases the blue ribbon cable.
    • Remove the analog stick and button cover.
  6. Nintendo Wii U GamePad Directional Pad Buttons Replacement: 手順 6、 1の画像 1
    • Use your thumb and push the connector towards the rightmost edge to disconnect the analog stick cable connector.
  7. Nintendo Wii U GamePad Directional Pad Buttons Replacement: 手順 7、 2の画像 1 Nintendo Wii U GamePad Directional Pad Buttons Replacement: 手順 7、 2の画像 2
    • Remove the two 9.0mm Tri-wing Y0 screws.
    • Lift out the analog stick.
    Easy peasy. Thanks!
    Elizabeth Fowler - 返信
    Hi there, I tried to replace the joystick following these instructions but I couldn't remove the connector cable from the old joystick as it is wired into the board. Does anyone know what the connector is called so I can buy one please!
    Spider Gin - 返信
    @Spider Gin The joystick and the tiny little control board (the pcb between the red circles in the picture of step 9) are purchased together (or at least that’s how I got mine). The only thing you need to disconnect on the analog stick assembly is the connector shown at the end of the thumb in the picture on step 8. If you are trying to disconnect the stick itself from the control board you are not looking at the right instructions for that.
    Mike South -
    It seems to me that Nintendo changed the design after a while some had the wires on a connector some were soldered in. I can't find much information about this. Going to have to disassemble what I have to find out what I need
    Blue Player -
    The volume slider came out when I turned the assembly upside down to retrieve a dropped screw. You need to pay attention when putting it back in to make sure you line up the groove on the slider with the tiny little square bump that fits into the groove and allows you to actually control the volume. It’s easy to get it aligned if you know that’s what you trying to do, but at first I didn’t even realize what it was.
    Anyway—it worked, thank you!
    Mike South - 返信
  8. Nintendo Wii U GamePad Directional Pad Buttons Replacement, Directional Pad Buttons: 手順 8、 2の画像 1 Nintendo Wii U GamePad Directional Pad Buttons Replacement, Directional Pad Buttons: 手順 8、 2の画像 2
    • Lift up and remove the rubber cover for the directional pad.
    • Remove the directional pad buttons.
終わりに
11 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Kim Arre
メンバー登録日: 01/11/13
4,918 ポイント
8のガイドは作成済み
チーム
Cal Poly, Team 17-20, Forte Winter 2013 Cal Poly, Team 17-20, Forte Winter 2013人のメンバー
CPSU-FORTE-W13S17G20
5 メンバー
38のガイドは作成済み
コメント 1 件
Where can you find the blue ribbon mentioned in step 5, for the buttons at?
Eric - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 25
過去 30 日: 144
今までの合計 19,964
