メインコンテンツにスキップ
Nintendo Wii U GamePad Directional Pad Buttons Replacement
必要な工具と部品
  1. Nintendo Wii U GamePad Directional Pad Buttons Replacement, Back Panel: 手順 1、 3の画像 1 Nintendo Wii U GamePad Directional Pad Buttons Replacement, Back Panel: 手順 1、 3の画像 2 Nintendo Wii U GamePad Directional Pad Buttons Replacement, Back Panel: 手順 1、 3の画像 3
    • Remove the ten 8.9mm Tri-wing Y1 screws hidden underneath square stickers.
    • Lift up the back plate.
    • The back plate is still connected by a cable to the motherboard.
  2. Nintendo Wii U GamePad Directional Pad Buttons Replacement: 手順 2、 2の画像 1 Nintendo Wii U GamePad Directional Pad Buttons Replacement: 手順 2、 2の画像 2
    • Unplug the connector that connects the back plate to the motherboard.
    • Remove the back panel.
  3. Nintendo Wii U GamePad Directional Pad Buttons Replacement, Analog Stick: 手順 3、 2の画像 1 Nintendo Wii U GamePad Directional Pad Buttons Replacement, Analog Stick: 手順 3、 2の画像 2
    • Take out the left and right shoulder buttons in the upper corners.
    • Remove the ZR and ZL trigger buttons by lifting up and sliding outward.
  4. Nintendo Wii U GamePad Directional Pad Buttons Replacement: 手順 4、 2の画像 1 Nintendo Wii U GamePad Directional Pad Buttons Replacement: 手順 4、 2の画像 2
    • Remove the top rubber cover by pulling it off of its mounts to access one of the mounting screws.
    • Remove the four 5.2mm Phillips #0 screws.
  5. Nintendo Wii U GamePad Directional Pad Buttons Replacement: 手順 5、 2の画像 1 Nintendo Wii U GamePad Directional Pad Buttons Replacement: 手順 5、 2の画像 2
    • Use a spudger to lift the tab which releases the blue ribbon cable.
    • Remove the analog stick and button cover.
  6. Nintendo Wii U GamePad Directional Pad Buttons Replacement: 手順 6、 1の画像 1
    • Use your thumb and push the connector towards the rightmost edge to disconnect the analog stick cable connector.
  7. Nintendo Wii U GamePad Directional Pad Buttons Replacement: 手順 7、 2の画像 1 Nintendo Wii U GamePad Directional Pad Buttons Replacement: 手順 7、 2の画像 2
    • Remove the two 9.0mm Tri-wing Y0 screws.
    • Lift out the analog stick.
  8. Nintendo Wii U GamePad Directional Pad Buttons Replacement, Directional Pad Buttons: 手順 8、 2の画像 1 Nintendo Wii U GamePad Directional Pad Buttons Replacement, Directional Pad Buttons: 手順 8、 2の画像 2
    • Lift up and remove the rubber cover for the directional pad.
    • Remove the directional pad buttons.
終わりに
11 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Kim Arre
メンバー登録日: 01/11/13
5,247 ポイント
8のガイドは作成済み
チーム
Cal Poly, Team 17-20, Forte Winter 2013 Cal Poly, Team 17-20, Forte Winter 2013人のメンバー
CPSU-FORTE-W13S17G20
5 メンバー
40のガイドは作成済み
コメント 1 件
Where can you find the blue ribbon mentioned in step 5, for the buttons at?
Eric - 返信
コメントを追加
統計データ:
過去 24時間: 8
過去 7 日: 29
過去 30 日: 152
今までの合計 21,510
