メインコンテンツにスキップ
Nintendo Wii Remote Motherboard Replacement
必要な工具と部品
  1. Nintendo Wii Remote Motherboard Replacement, Front Cover Plate and Batteries: 手順 1、 2の画像 1 Nintendo Wii Remote Motherboard Replacement, Front Cover Plate and Batteries: 手順 1、 2の画像 2
    • Flip the Wii Remote over so the battery cover faces you.
    • Push up on the bottom tab.
    • Remove the battery cover.
  2. Nintendo Wii Remote Motherboard Replacement: 手順 2、 1の画像 1
    • Remove the first battery by pressing down on the positive end and pulling the battery out.
    • Remove the second battery by pushing up on the positive end and pulling the battery out.
  3. Nintendo Wii Remote Motherboard Replacement: 手順 3、 1の画像 1
    • Using a tri-point Y1 Screwdriver, remove the two center 7mm screws by turning them counterclockwise.
    • Repeat with the two bottom screws.
  4. Nintendo Wii Remote Motherboard Replacement: 手順 4、 2の画像 1 Nintendo Wii Remote Motherboard Replacement: 手順 4、 2の画像 2
    • With the flat end of a spudger, gently apply pressure to the tabs located on left side of the controller.
    • These tabs are breakable. However, if the tabs are broken the controller will still function.
    • Open the front plate like a book.
    • Small parts may fall out as you open the front plate.
  5. Nintendo Wii Remote Motherboard Replacement, Motherboard: 手順 5、 2の画像 1 Nintendo Wii Remote Motherboard Replacement, Motherboard: 手順 5、 2の画像 2
    • Using the connector port, gently lift the motherboard about 2 cm from the base.
    • Electrostatic discharge may damage the device. Be careful and avoid touching the electronic components as much as possible.
  6. Nintendo Wii Remote Motherboard Replacement: 手順 6、 2の画像 1 Nintendo Wii Remote Motherboard Replacement: 手順 6、 2の画像 2
    • Grasp the edges of the motherboard and pull it straight away from the case.
終わりに
21 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Emily
メンバー登録日: 04/14/13
1,185 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 3-44, Amido Spring 2013 Cal Poly, Team 3-44, Amido Spring 2013人のメンバー
CPSU-AMIDO-S13S3G44
4 メンバー
21のガイドは作成済み
6 件のコメント
Where do you find a motherboard and how much do they typically cost?
Jeff - 返信
This is useless because you can't just buy a motherboard. May as well buy a new remote for $20
Lisa Cole - 返信
Where can i buy a brand new and original (not fake of course) wii remote for $20?
arttitudesign -
You can buy a first party Wii remote plus for under $50 at Walmart, best buy, or online on Amazon or on Nintendos website
Darren Woloshyn - 返信
What is the dimension is the motherboard? I want to make a custom motherboard for the housing but I haven't managed to get int the wiimote yet as I am waiting for my tri screwdriver
Michael baldwin - 返信
コメントを追加
統計データ:
過去 24時間: 8
過去 7 日: 88
過去 30 日: 327
今までの合計 27,052
