はじめに
Most disc read errors (DREs) can be fixed by replacing the laser lens in your Wii's DVD drive.
必要な工具と部品
Use a metal spudger to remove the white plastic screw covers stuck to the lower case near the front of the Wii.
Open the controller port cover until it is perpendicular to the black controller port bezel.
Pull the controller port cover straight up to release it from the outer case.
Remove the small Phillips screw securing the battery door to the bottom panel.
Pull the battery door out of the Wii.
While holding the DVD drive with one hand, grasp the DVD drive lens retaining pin (closest to the screw that was just removed) with a pair of needle nose pliers.
Slide the retaining pin out towards the edge of the DVD drive housing.
Once the pin moves easily, grab it with your fingers and pull it out of the DVD drive housing completely.
137 の人々がこのガイドを完成させました。
25 件のコメント
Many thanks for the excellent guide - my wii is working again!
This is one of the best set of instructions I have ever used. Easy to follow steps with accurate illustrations. Very well done, I don't know how you could make it any better! A++,
