はじめに
The Nintendo WaveBird wireless controller channel wheel guide will allow the user to change the channel wheel if it won’t turn. Prior to replacing the part, ensure that dirt clogging the wheel is not the cause of malfunctioning. If the wheel and controller is clean and the wheel still fails to turn, a faulty channel wheel is likely the issue.
While replacing the channel wheel, take care with removing the motherboard to avoid damaging the motherboard. In addition, check the condition of the AA batteries to ensure that they are not swollen or leaking.
必要な工具と部品
Remove the eight 9 mm screws from the back panel using the Tri-point Y1 screwdriver.
この手順で使用する道具:Tweezers$4.99
Using tweezers remove the three grey button pads from the motherboard.
2 の人々がこのガイドを完成させました。
