Remove the eight 9 mm screws from the back panel using the Tri-point Y1 screwdriver.
During reassembly, firmly hold the panels of the controller together while replacing the screws so the panels do not separate.
Carefully turn over the controller and place it on a flat surface.
Slowly separate the top panel from the bottom panel.
The buttons are loose and may fall off the motherboard.
Once separated, set aside the top panel.
During reassembly, make sure the front panel lines up with the buttons so they slide back into place.
Use tweezers to remove the buttons.
It may be easier to remove the A button off of the pad by lifting it with your fingers.
During reassembly, make sure all buttons are in their respective sockets so they match up with the front panel.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
