はじめに
This is a prerequisite-only guide! This guide is part of another procedure and is not meant to be used alone.
必要な工具と部品
この手順で使用する道具:Magnetic Project Mat$19.95
Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the back panel.
Use a JIS 000 driver or an official iFixit PH 000 driver to remove the following screws securing the back panel:
Two 3.6 mm-long screws on the top of the device
Two 3.6 mm-long screws on the bottom of the device
Insert an opening tool into the left speaker grille on the bottom of the device.
Twist the opening tool to release the clips securing the back panel.
Slide the opening tool around the bottom-left corner to release the clips on the left side of the device.
Insert an opening tool into the right speaker grille on the bottom of the device.
Twist the opening tool to release the clips.
Slide and pry the opening tool around the bottom-right corner to release the clips on the right side of the device.
Lift the bottom edge of the back panel, opening it like a book.
Remove the back panel.
Use a JIS 000 driver or an official iFixit PH 000 driver to remove the following four screws:
Three 3.1 mm screws
One 4.5 mm screw
Use an opening tool or your fingernail to flip up the small, hinged locking flap on the motherboard interconnect cable's ZIF connector.
Use the flat end of a spudger or your fingers to carefully peel up the foam that's lightly adhered to the fan.
Use an opening tool or your fingernail to flip up the small, hinged locking flap on the game card reader cable's ZIF connector.
Use a Phillips screwdriver to remove the two 4.5 mm screws securing the right trigger button assembly to the motherboard.
Use the point of a spudger to pry the black antenna cable straight up out of its socket on the motherboard.
Repeat the same process for the white antenna cable.
Use an opening tool or your fingernail to flip up the small, hinged locking flap on the fan cable's ZIF connector.
Use an opening tool or your fingernail to flip up the small, hinged locking flap on the screen cable's ZIF connector.
Use an opening tool or your fingernail to flip up the small, hinged locking flap on the digitizer cable's ZIF connector.
Use an opening tool or your fingernail to flip up the small, hinged locking flap on the right joystick cable's ZIF connector.
Use a Phillips screwdriver to remove the following six screws securing the motherboard:
Three 3.1 mm screws
Three 4.5 mm screws
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch Lite Answers community for help.
