メインコンテンツにスキップ
Nintendo Switch 2 Battery Replacement
必要な工具と部品
  1. Nintendo Switch 2 Battery Replacement, Power off the console: 手順 1、 3の画像 1 Nintendo Switch 2 Battery Replacement, Power off the console: 手順 1、 3の画像 2 Nintendo Switch 2 Battery Replacement, Power off the console: 手順 1、 3の画像 3
    • For your safety, discharge the battery below 25% before disassembling the console. This reduces the risk of a fire if the battery is damaged during the repair. If the battery is swollen, take appropriate precautions.
    • Remove any game cards and disconnect any cables, controllers, or other accessories from the console.
    • Power off the console by holding down the power button, selecting Power Options, then pressing Power Off.
  2. Nintendo Switch 2 Battery Replacement, Remove the bottom screws: 手順 2、 2の画像 1 Nintendo Switch 2 Battery Replacement, Remove the bottom screws: 手順 2、 2の画像 2
    • Use a JIS 00 driver to remove the two 3.1 mm‑long screws on either side of the bottom USB-C port.
    • You can try a non-iFixit Phillips driver in a pinch, but you risk damaging or stripping the screw. Push down firmly on the driver and twist slowly.
  3. Nintendo Switch 2 Battery Replacement, Remove the top screw: 手順 3、 2の画像 1 Nintendo Switch 2 Battery Replacement, Remove the top screw: 手順 3、 2の画像 2
    • Use a JIS 00 driver to remove the 3.1 mm‑long screw on the top edge of the console (next to the ventilation cutouts).
  4. Nintendo Switch 2 Battery Replacement, Heat the right side sticker: 手順 4、 1の画像 1
    • The Switch 2 has stickers on either side that need to removed to access the screws securing the back cover. It's easy to damage the stickers during removal, but you can mitigate this by regularly reheating the stickers and working carefully.
    • Use a hair dryer or heat gun to heat the sticker on the right side of the console, labeled with a "+" symbol, until it's hot to the touch.
    • You can use the kickstand to prop the console up vertically for easier access.
    • If you're using a heat gun, set it to low to avoid melting the plastic edge of the console.
  5. Nintendo Switch 2 Battery Replacement, Pry up the right side sticker: 手順 5、 3の画像 1 Nintendo Switch 2 Battery Replacement, Pry up the right side sticker: 手順 5、 3の画像 2 Nintendo Switch 2 Battery Replacement, Pry up the right side sticker: 手順 5、 3の画像 3
    • The pointed end of the tweezers can damage the sticker from the underside, leaving a noticeable mark. If it's difficult to lift, apply more heat instead of using more force.
    • Slide one arm of angled tweezers underneath the sticker from its cutout around the right Joy‑Con 2 connector.
    • Gently pry up on the sticker until it starts to lift from the console.
    • Leave the tweezers in place to keep the sticker lifted.
  6. Nintendo Switch 2 Battery Replacement: 手順 6、 3の画像 1 Nintendo Switch 2 Battery Replacement: 手順 6、 3の画像 2 Nintendo Switch 2 Battery Replacement: 手順 6、 3の画像 3
    この手順で使用する道具:
    Jimmy
    $7.16
    • Insert the tip of a Jimmy into the gap formed between the long edge of the console and the sticker.
    • Gently pry up the sticker, working your way up the long edge until the top of the sticker is separated from the console.
    • Remove the tweezers once the sticker is lifted.
    • You can leave the Jimmy in place to hold the top of the sticker off the frame—if it falls back into its recess, repeat this procedure to lift it back up.
  7. Nintendo Switch 2 Battery Replacement, Heat the right side sticker: 手順 7、 1の画像 1
    • Reheat the bottom of the right side until it's hot to the touch.
  8. Nintendo Switch 2 Battery Replacement, Remove the right side sticker: 手順 8、 3の画像 1 Nintendo Switch 2 Battery Replacement, Remove the right side sticker: 手順 8、 3の画像 2 Nintendo Switch 2 Battery Replacement, Remove the right side sticker: 手順 8、 3の画像 3
    • Carefully lift the sticker over the Joy‑Con 2 connector, then peel it up fully to remove it.
  9. Nintendo Switch 2 Battery Replacement, Remove the left side sticker: 手順 9、 3の画像 1 Nintendo Switch 2 Battery Replacement, Remove the left side sticker: 手順 9、 3の画像 2 Nintendo Switch 2 Battery Replacement, Remove the left side sticker: 手順 9、 3の画像 3
    • Repeat this procedure to remove the sticker along the left side of the console, labeled with a "-" symbol.
  10. Nintendo Switch 2 Battery Replacement, Remove the side screws: 手順 10、 2の画像 1 Nintendo Switch 2 Battery Replacement, Remove the side screws: 手順 10、 2の画像 2
    • Use a JIS 00 driver to remove the two 3.6 mm‑long gold screws on each side of the console (four in total).
  11. Nintendo Switch 2 Battery Replacement, Open the kickstand: 手順 11、 3の画像 1 Nintendo Switch 2 Battery Replacement, Open the kickstand: 手順 11、 3の画像 2 Nintendo Switch 2 Battery Replacement, Open the kickstand: 手順 11、 3の画像 3
    • Use your fingers to flip up the kickstand on the back of the console.
    • If there's a microSD Express card installed, remove it now before you continue to the next step.
  12. Nintendo Switch 2 Battery Replacement, Remove the back-side screws: 手順 12、 2の画像 1 Nintendo Switch 2 Battery Replacement, Remove the back-side screws: 手順 12、 2の画像 2
    • Use a Y00 driver to remove the two 4.4 mm‑long screws in the kickstand cutout.
  13. Nintendo Switch 2 Battery Replacement, Insert an opening pick: 手順 13、 2の画像 1 Nintendo Switch 2 Battery Replacement, Insert an opening pick: 手順 13、 2の画像 2
    • Insert an opening pick into the gap between the back cover and speaker cutout on the bottom edge of the console.
  14. Nintendo Switch 2 Battery Replacement: 手順 14、 2の画像 1 Nintendo Switch 2 Battery Replacement: 手順 14、 2の画像 2
    • Slide the opening pick towards the USB-C port until it's underneath the screw hole next to the port.
  15. Nintendo Switch 2 Battery Replacement, Insert a second opening pick: 手順 15、 3の画像 1 Nintendo Switch 2 Battery Replacement, Insert a second opening pick: 手順 15、 3の画像 2 Nintendo Switch 2 Battery Replacement, Insert a second opening pick: 手順 15、 3の画像 3
    • Insert a second opening pick underneath the screw hole on the opposite side of the USB-C port, and slide it to the corner of the console.
  16. Nintendo Switch 2 Battery Replacement: 手順 16、 2の画像 1 Nintendo Switch 2 Battery Replacement: 手順 16、 2の画像 2
    • Slide the first opening pick back to where it was first inserted.
  17. Nintendo Switch 2 Battery Replacement, Remove the back cover: 手順 17、 3の画像 1 Nintendo Switch 2 Battery Replacement, Remove the back cover: 手順 17、 3の画像 2 Nintendo Switch 2 Battery Replacement, Remove the back cover: 手順 17、 3の画像 3
    • Be careful not to drop your console. Once the back cover pops up, the opening picks will fall out of place.
    • Hold the console with two hands. Rest your thumbs on the opening picks.
    • Push up on the opening picks to lift the back cover until it pops up above the USB-C port.
  18. Nintendo Switch 2 Battery Replacement: 手順 18、 3の画像 1 Nintendo Switch 2 Battery Replacement: 手順 18、 3の画像 2 Nintendo Switch 2 Battery Replacement: 手順 18、 3の画像 3
    • Lift the back cover up from the bottom edge and remove it.
  19. Nintendo Switch 2 Battery Replacement, Remove the lower antenna screws: 手順 19、 2の画像 1 Nintendo Switch 2 Battery Replacement, Remove the lower antenna screws: 手順 19、 2の画像 2
    • Use a JIS 00 driver to remove the three 4.4 mm‑long silver screws securing the lower antenna.
  20. Nintendo Switch 2 Battery Replacement, Remove the lower antenna: 手順 20、 2の画像 1 Nintendo Switch 2 Battery Replacement, Remove the lower antenna: 手順 20、 2の画像 2
    • Use tweezers or your fingers to remove the lower antenna.
  21. Nintendo Switch 2 Battery Replacement, Remove the upper antenna screws: 手順 21、 2の画像 1 Nintendo Switch 2 Battery Replacement, Remove the upper antenna screws: 手順 21、 2の画像 2
    • Use a JIS 00 driver to remove the two screws securing the upper antenna:
    • One 4.4 mm‑long silver screw
    • One 4.6 mm‑long green screw
  22. Nintendo Switch 2 Battery Replacement, Remove the upper antenna: 手順 22、 2の画像 1 Nintendo Switch 2 Battery Replacement, Remove the upper antenna: 手順 22、 2の画像 2
    • Use tweezers or your fingers to remove the upper antenna.
  23. Nintendo Switch 2 Battery Replacement, Disconnect the lower antenna cable: 手順 23、 3の画像 1 Nintendo Switch 2 Battery Replacement, Disconnect the lower antenna cable: 手順 23、 3の画像 2 Nintendo Switch 2 Battery Replacement, Disconnect the lower antenna cable: 手順 23、 3の画像 3
    • Insert an arm of angled tweezers under the metal neck of the white interconnect cable coaxial connector (located beneath the lower antenna) and lift straight up to disconnect it.
  24. Nintendo Switch 2 Battery Replacement, Disconnect the remaining antenna cables: 手順 24、 3の画像 1 Nintendo Switch 2 Battery Replacement, Disconnect the remaining antenna cables: 手順 24、 3の画像 2 Nintendo Switch 2 Battery Replacement, Disconnect the remaining antenna cables: 手順 24、 3の画像 3
    • Repeat this procedure to disconnect the three central coaxial connectors from the board.
  25. Nintendo Switch 2 Battery Replacement, Disconnect the MicroSD connector: 手順 25、 3の画像 1 Nintendo Switch 2 Battery Replacement, Disconnect the MicroSD connector: 手順 25、 3の画像 2 Nintendo Switch 2 Battery Replacement, Disconnect the MicroSD connector: 手順 25、 3の画像 3
    • Use the flat end of a spudger to pry up and disconnect the MicroSD card reader press connector, located next to the bottom USB‑C port.
  26. Nintendo Switch 2 Battery Replacement, Remove the shield plate screws: 手順 26、 2の画像 1 Nintendo Switch 2 Battery Replacement, Remove the shield plate screws: 手順 26、 2の画像 2
    • Use a JIS 00 driver to remove the seven screws securing the shield plate:
    • Two 6.2 mm‑long silver screws
    • Five 4.4 mm‑long silver screws
  27. Nintendo Switch 2 Battery Replacement, Lift the shield plate: 手順 27、 3の画像 1 Nintendo Switch 2 Battery Replacement, Lift the shield plate: 手順 27、 3の画像 2 Nintendo Switch 2 Battery Replacement, Lift the shield plate: 手順 27、 3の画像 3
    • Insert the flat end of a spudger between the shield plate and the processor's heat sink, next to the square (⛶) marking on the shield plate.
    • Twist the spudger to lift the shield plate and separate the thermal putty bonded to it. Keep lifting the shield plate until you don't feel resistance.
  28. Nintendo Switch 2 Battery Replacement: 手順 28、 3の画像 1 Nintendo Switch 2 Battery Replacement: 手順 28、 3の画像 2 Nintendo Switch 2 Battery Replacement: 手順 28、 3の画像 3
    • Lift the left edge of the shield plate to ensure it's fully separated from the thermal putty.
    • Gently set the shield plate back down.
  29. Nintendo Switch 2 Battery Replacement, Unroute the gray antenna cable: 手順 29、 3の画像 1 Nintendo Switch 2 Battery Replacement, Unroute the gray antenna cable: 手順 29、 3の画像 2 Nintendo Switch 2 Battery Replacement, Unroute the gray antenna cable: 手順 29、 3の画像 3
    • Insert one arm of angled tweezers underneath the gray antenna cable at the bottom-right corner of the console.
    • Lift the cable out of the black clip securing it to the frame.
  30. Nintendo Switch 2 Battery Replacement: 手順 30、 3の画像 1 Nintendo Switch 2 Battery Replacement: 手順 30、 3の画像 2 Nintendo Switch 2 Battery Replacement: 手順 30、 3の画像 3
    • Unroute the gray antenna cable from its channel along the right edge of the console.
  31. Nintendo Switch 2 Battery Replacement: 手順 31、 2の画像 1 Nintendo Switch 2 Battery Replacement: 手順 31、 2の画像 2
    • Lift and slide the shield plate away from the right edge of the console until the gray antenna cable is completely free.
  32. Nintendo Switch 2 Battery Replacement, Remove the shield plate: 手順 32、 2の画像 1 Nintendo Switch 2 Battery Replacement, Remove the shield plate: 手順 32、 2の画像 2
    • Pick up and remove the shield plate.
  33. Nintendo Switch 2 Battery Replacement, Disconnect the battery: 手順 33、 2の画像 1 Nintendo Switch 2 Battery Replacement, Disconnect the battery: 手順 33、 2の画像 2
    • Insert the flat end of a spudger underneath the flat-topped battery connector, located next to the battery, and pry up to disconnect it.
  34. Nintendo Switch 2 Battery Replacement, Weaken the adhesive: 手順 34、 1の画像 1
    この手順で使用する道具:
    iFixit Adhesive Remover
    $19.99
    • Tilt the bottom edge of the console upward.
    • Apply a few drops of adhesive remover or high-concentration (90% or higher) isopropyl alcohol inside the battery well from its bottom cutout to weaken the adhesive.
    • Make sure not to puncture or scrape the bottom of the battery.
    • If you're using adhesive remover, follow these preparation steps first.
    • Hold the console upright for 1–2 minutes for the solvent to flow under the battery and weaken the adhesive.
  35. Nintendo Switch 2 Battery Replacement, Lift the battery: 手順 35、 3の画像 1 Nintendo Switch 2 Battery Replacement, Lift the battery: 手順 35、 3の画像 2 Nintendo Switch 2 Battery Replacement, Lift the battery: 手順 35、 3の画像 3
    • Don't bend the battery. If you see the battery bending, or if you're having difficulty prying, apply more solvent.
    • Insert the flat end of a spudger underneath the battery from the battery well cutout.
    • Slowly pry the battery up until its adhesive is fully separated from the frame. You can pry against the metal grille along the bottom edge of the console.
  36. Nintendo Switch 2 Battery Replacement, Remove the battery: 手順 36、 1の画像 1
    • Remove the battery.
  37. Nintendo Switch 2 Battery Replacement, Disassembly complete: 手順 37、 1の画像 1
    • Congratulations on completing disassembly! The remaining steps will show how to reassemble your console.
  38. Nintendo Switch 2 Battery Replacement, Clean the battery well: 手順 38、 2の画像 1 Nintendo Switch 2 Battery Replacement, Clean the battery well: 手順 38、 2の画像 2
    この手順で使用する道具:
    Cotton Swabs
    • Apply high-concentration (90% or higher) isopropyl alcohol to a cotton swab and wipe any adhesive residue from the battery well.
    • The foam on the inside walls of the well dissolves in isopropyl alcohol. Avoid touching the foam with your cotton swab so you don't damage it.
  39. Nintendo Switch 2 Battery Replacement, Transfer the foam: 手順 39、 2の画像 1 Nintendo Switch 2 Battery Replacement, Transfer the foam: 手順 39、 2の画像 2
    • If your new battery comes with foam pre-installed, skip the next two steps.
    • Use an opening pick or your fingernail to lift the foam strip off the top edge of the battery by its adhesive, not the foam itself.
  40. Nintendo Switch 2 Battery Replacement: 手順 40、 2の画像 1 Nintendo Switch 2 Battery Replacement: 手順 40、 2の画像 2
    • Peel the entire sticker, including the foam, from the front of the battery.
  41. Nintendo Switch 2 Battery Replacement: 手順 41、 2の画像 1 Nintendo Switch 2 Battery Replacement: 手順 41、 2の画像 2
    • Install the foam stickers in their original positions onto the new battery.
  42. Nintendo Switch 2 Battery Replacement, Prepare the adhesive: 手順 42、 3の画像 1 Nintendo Switch 2 Battery Replacement, Prepare the adhesive: 手順 42、 3の画像 2 Nintendo Switch 2 Battery Replacement, Prepare the adhesive: 手順 42、 3の画像 3
    この手順で使用する道具:
    Tesa 61395 Tape
    $2.99
    • If your battery doesn't come with pre-installed adhesive, apply 5 mm‑wide strips of thin, double-sided tape to the flat area on the bottom of the battery. Don't install adhesive along the angled parts of the edges.
    • Remove all adhesive backings.
  43. Nintendo Switch 2 Battery Replacement, Install the new battery: 手順 43、 3の画像 1 Nintendo Switch 2 Battery Replacement, Install the new battery: 手順 43、 3の画像 2 Nintendo Switch 2 Battery Replacement, Install the new battery: 手順 43、 3の画像 3
    • Align the battery with its well, ensuring the cable aligns with its cutout.
    • Carefully lower the battery into the frame.
    • Once the adhesive sticks on more than one side, don't try to lift and reposition the battery.
    • Gently press down on the battery for around 20 seconds to adhere it to the frame.
  44. Nintendo Switch 2 Battery Replacement, Connect the battery: 手順 44、 2の画像 1 Nintendo Switch 2 Battery Replacement, Connect the battery: 手順 44、 2の画像 2
    • Use your finger or the flat end of a spudger to press the flat-topped battery connector onto its socket until it's fully seated.
  45. Nintendo Switch 2 Battery Replacement, Clean the heat pipe: 手順 45、 3の画像 1 Nintendo Switch 2 Battery Replacement, Clean the heat pipe: 手順 45、 3の画像 2 Nintendo Switch 2 Battery Replacement, Clean the heat pipe: 手順 45、 3の画像 3
    この手順で使用する道具:
    Arctic Silver ArctiClean
    $9.99
    • If you don't have replacement thermal putty, use the flat end of a spudger to distribute the old putty evenly across the heat pipe, as thick as possible to ensure proper contact. Repeat this process on the shield plate, then skip this step.
    • Use the flat end of a spudger to scrape off the thermal putty on top of the copper heat pipe.
    • Apply high-concentration (90% or higher) isopropyl alcohol or thermal material remover to a cotton swab or lint-free cloth and wipe away any remaining thermal putty on both the heat pipe and shield plate.
    • Don't use a paper towel or rag, as they may scratch the shield plate.
  46. Nintendo Switch 2 Battery Replacement, Apply thermal putty: 手順 46、 3の画像 1 Nintendo Switch 2 Battery Replacement, Apply thermal putty: 手順 46、 3の画像 2 Nintendo Switch 2 Battery Replacement, Apply thermal putty: 手順 46、 3の画像 3
    この手順で使用する道具:
    iFixit Thermal Putty
    $9.95
    • Apply a line of new thermal putty down the center of the heat pipe, roughly the thickness of a pea.
  47. Nintendo Switch 2 Battery Replacement, Route the gray antenna cable: 手順 47、 3の画像 1 Nintendo Switch 2 Battery Replacement, Route the gray antenna cable: 手順 47、 3の画像 2 Nintendo Switch 2 Battery Replacement, Route the gray antenna cable: 手順 47、 3の画像 3
    • Hold the top‑right corner of the shield plate above the top‑right corner of the console.
    • Route the gray antenna cable underneath the black hook near the top corner of the frame.
  48. Nintendo Switch 2 Battery Replacement, Lower the shield plate: 手順 48、 2の画像 1 Nintendo Switch 2 Battery Replacement, Lower the shield plate: 手順 48、 2の画像 2
    • Lower the shield plate into place and align it with its screw holes.
  49. Nintendo Switch 2 Battery Replacement, Finish routing the gray antenna cable: 手順 49、 3の画像 1 Nintendo Switch 2 Battery Replacement, Finish routing the gray antenna cable: 手順 49、 3の画像 2 Nintendo Switch 2 Battery Replacement, Finish routing the gray antenna cable: 手順 49、 3の画像 3
    • Route the gray antenna cable down its channel on the right edge of the frame.
  50. Nintendo Switch 2 Battery Replacement: 手順 50、 3の画像 1 Nintendo Switch 2 Battery Replacement: 手順 50、 3の画像 2 Nintendo Switch 2 Battery Replacement: 手順 50、 3の画像 3
    • Press the gray antenna cable into its groove at the bottom of its channel, and continue routing until it's secured to the clip at the bottom of the frame.
  51. Nintendo Switch 2 Battery Replacement, Install the shield plate screws: 手順 51、 2の画像 1 Nintendo Switch 2 Battery Replacement, Install the shield plate screws: 手順 51、 2の画像 2
    • Use a JIS 00 driver to install the seven screws securing the shield plate:
  52. Nintendo Switch 2 Battery Replacement, Connect the MicroSD connector: 手順 52、 2の画像 1 Nintendo Switch 2 Battery Replacement, Connect the MicroSD connector: 手順 52、 2の画像 2
    • Use your finger or the flat end of a spudger to press the MicroSD card reader press connector onto its socket on the board.
    • Don't try to force the connector into place. If you're having trouble, reposition it and try again.
  53. Nintendo Switch 2 Battery Replacement, Connect the antenna cables: 手順 53、 3の画像 1 Nintendo Switch 2 Battery Replacement, Connect the antenna cables: 手順 53、 3の画像 2 Nintendo Switch 2 Battery Replacement, Connect the antenna cables: 手順 53、 3の画像 3
    • Use tweezers to hold the lower antenna coaxial connector in place over its socket and gently press down with your finger or a spudger—the connector should "snap" into place. If you're having trouble, reposition the head instead of using more force.
    • Repeat this process to connect the three central coaxial connectors to their respective sockets.
    • The black cable connects to the socket closest to the fan, the white to the middle, and the gray the furthest away.
  54. Nintendo Switch 2 Battery Replacement, Install the upper antenna: 手順 54、 3の画像 1 Nintendo Switch 2 Battery Replacement, Install the upper antenna: 手順 54、 3の画像 2 Nintendo Switch 2 Battery Replacement, Install the upper antenna: 手順 54、 3の画像 3
    • Use tweezers or your fingers to align the upper antenna with its screw holes and black alignment pegs and set it into place.
    • Use a JIS 00 driver to install the two screws securing the upper antenna:
  55. Nintendo Switch 2 Battery Replacement, Install the lower antenna: 手順 55、 3の画像 1 Nintendo Switch 2 Battery Replacement, Install the lower antenna: 手順 55、 3の画像 2 Nintendo Switch 2 Battery Replacement, Install the lower antenna: 手順 55、 3の画像 3
    • Use tweezers or your fingers to align the lower antenna with its screw holes and gray alignment pegs and set it into place.
    • Use a JIS 00 driver to install the three 4.4 mm‑long screws securing the lower antenna.
  56. Nintendo Switch 2 Battery Replacement, Prepare the back cover: 手順 56、 3の画像 1 Nintendo Switch 2 Battery Replacement, Prepare the back cover: 手順 56、 3の画像 2 Nintendo Switch 2 Battery Replacement, Prepare the back cover: 手順 56、 3の画像 3
    • Fully pull out the game card tray.
    • Double-check the power and volume buttons to ensure they're seated correctly. If the rubber membrane beneath the buttons is out of place, ensure it's aligned with its pegs.
    • Check the microphone to ensure it's fully seated in its slot in the frame.
  57. Nintendo Switch 2 Battery Replacement, Install the back cover: 手順 57、 3の画像 1 Nintendo Switch 2 Battery Replacement, Install the back cover: 手順 57、 3の画像 2 Nintendo Switch 2 Battery Replacement, Install the back cover: 手順 57、 3の画像 3
    • Align the top of the back cover with the top of the console.
    • Set the top edge of the back cover into place, checking the buttons and ports to ensure they're aligned properly. If they aren't, lift the back cover and try again.
    • Press along the top edge to fasten the clips securing the back cover to the console.
  58. Nintendo Switch 2 Battery Replacement: 手順 58、 2の画像 1 Nintendo Switch 2 Battery Replacement: 手順 58、 2の画像 2
    • Squeeze the rest of the back cover and console together to fasten the clips.
  59. Nintendo Switch 2 Battery Replacement, Install the back-side screws: 手順 59、 3の画像 1 Nintendo Switch 2 Battery Replacement, Install the back-side screws: 手順 59、 3の画像 2 Nintendo Switch 2 Battery Replacement, Install the back-side screws: 手順 59、 3の画像 3
    • Use a JIS 00 driver to install the three 3.1 mm‑long screws securing the back cover: one on the top edge of the console, and two on either side of the bottom USB-C port.
    • Use a Y00 driver to install the two 4.4 mm‑long screws in the kickstand cutout.
  60. Nintendo Switch 2 Battery Replacement, Install the side screws: 手順 60、 2の画像 1 Nintendo Switch 2 Battery Replacement, Install the side screws: 手順 60、 2の画像 2
    • Install the two 3.6 mm‑long gold screws on each side of the console (four in total).
  61. Nintendo Switch 2 Battery Replacement, Test the console: 手順 61、 2の画像 1 Nintendo Switch 2 Battery Replacement, Test the console: 手順 61、 2の画像 2
    • Power on the console and test functionality to ensure it's working as expected.
  62. Nintendo Switch 2 Battery Replacement, Install the stickers: 手順 62、 3の画像 1 Nintendo Switch 2 Battery Replacement, Install the stickers: 手順 62、 3の画像 2 Nintendo Switch 2 Battery Replacement, Install the stickers: 手順 62、 3の画像 3
    • Align the right side sticker with its recess. Ensure the cutout in the sticker is aligned with the Joy-Con connector.
    • Set the sticker into its recess, first on one side, then the other.
    • Use your finger or the flat end of a spudger to press the sticker into place.
    • If the sticker isn't sticking well, apply heat after you press it into place.
  63. Nintendo Switch 2 Battery Replacement: 手順 63、 3の画像 1 Nintendo Switch 2 Battery Replacement: 手順 63、 3の画像 2 Nintendo Switch 2 Battery Replacement: 手順 63、 3の画像 3
    • Repeat this procedure to install the left side sticker.
終わりに
You finished fixing your Switch 2!
Don't throw your battery in the trash. Click here to learn how to dispose of it properly.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch 2 Answers Community for help.
ある他の人がこのガイドを完成しました。
Nick Schultz
メンバー登録日: 03/24/24
36,927 ポイント
224のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 22
過去 7 日: 177
過去 30 日: 772
今までの合計 2,831
