メインコンテンツにスキップ
Nintendo Super Famicom SHVC-001 Cartridge Port Replacement
必要な工具と部品
  1. Nintendo Super Famicom SHVC-001 Cartridge Port Replacement, Upper Case: 手順 1、 1の画像 1
    • Remove the six 13.5 mm screws on the lower case with a 4.5 mm Gamebit screwdriver.
  2. Nintendo Super Famicom SHVC-001 Cartridge Port Replacement: 手順 2、 2の画像 1 Nintendo Super Famicom SHVC-001 Cartridge Port Replacement: 手順 2、 2の画像 2
    • Flip the Famicom over and set it down.
    • Lift off the upper case.
  3. Nintendo Super Famicom SHVC-001 Cartridge Port Replacement, Cartridge Port: 手順 3、 1の画像 1
    • Remove the mechanism by lifting the axle slightly to the right and drawing it out.
    • A tiny spring holds the mechanism back in place. It's not too tense, but take care not to lose it. Also, take note of how it is arranged for future reassembly.
  4. Nintendo Super Famicom SHVC-001 Cartridge Port Replacement: 手順 4、 2の画像 1 Nintendo Super Famicom SHVC-001 Cartridge Port Replacement: 手順 4、 2の画像 2
    • Use a Phillips screwdriver to remove the two screws that secure the power switch.
    • The power switch is connected to the main board via a little plastic connection; grip the motherboard connector and pull it straight out of its port.
    • Do not pull on the wires to avoid harming them. Instead, pull on the plastic connector.
  5. Nintendo Super Famicom SHVC-001 Cartridge Port Replacement: 手順 5、 3の画像 1 Nintendo Super Famicom SHVC-001 Cartridge Port Replacement: 手順 5、 3の画像 2 Nintendo Super Famicom SHVC-001 Cartridge Port Replacement: 手順 5、 3の画像 3
    • Carefully pull the ribbon cable that is attached to the controller board and the main board.
    • Remove the controller port.
  6. Nintendo Super Famicom SHVC-001 Cartridge Port Replacement: 手順 6、 2の画像 1 Nintendo Super Famicom SHVC-001 Cartridge Port Replacement: 手順 6、 2の画像 2
    • Use a Phillips screwdriver to remove the six 15.6 mm screws that secure the silver protective shield.
    • Remove the silver shield.
  7. Nintendo Super Famicom SHVC-001 Cartridge Port Replacement: 手順 7、 2の画像 1 Nintendo Super Famicom SHVC-001 Cartridge Port Replacement: 手順 7、 2の画像 2
    • Lift the cartridge slot up and out of the device.
  8. Nintendo Super Famicom SHVC-001 Cartridge Port Replacement: 手順 8、 2の画像 1 Nintendo Super Famicom SHVC-001 Cartridge Port Replacement: 手順 8、 2の画像 2
    • If the contacts are rusted or corroded, use a cotton swab damp with high-concentration isopropyl alcohol to remove the rust.
  9. Nintendo Super Famicom SHVC-001 Cartridge Port Replacement: 手順 9、 1の画像 1
    • Replace the cartridge slot.
終わりに
作成者
2人の作成者と共同で作成されました。
Carter Eason
メンバー登録日: 02/05/24
454 ポイント
4のガイドは作成済み
チーム
University of North Texas, Team 2-3, Kilpatrick Spring 2024 University of North Texas, Team 2-3, Kilpatrick Spring 2024人のメンバー
UNT-KILPATRICK-S24S2G3
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 44
今までの合計 79
