はじめに
Removing the top case will allow you access to the GameCube's internal parts.
必要な工具と部品
Turn over the Gamecube so that the bottom side is facing up.
Locate the four screws (circled in red) on each corner of the device. Then, use a 4.5 mm Gamebit screwdriver to remove all four screws.
13 の人々がこのガイドを完成させました。
コメント 1 件
Can you do a more in-depth version of the top cover? I had to clean each piece and need help figuring out where all the pieces go. Thanks
JJ Jackson - 返信
