メインコンテンツにスキップ
Nintendo Game Boy Advance SP Brightness Switch Replacement
必要な工具と部品
  1. Nintendo Game Boy Advance SP Brightness Switch Replacement, Battery: 手順 1、 1の画像 1
    • Use a standard Phillips #00 screwdriver to loosen the 4 mm screw that keeps the battery cover attached to the device.
  2. Nintendo Game Boy Advance SP Brightness Switch Replacement: 手順 2、 1の画像 1
    • Lift the battery cover up and remove it from the device.
    • The screw will remain attached to the battery cover because of Nintendo's design.
  3. Nintendo Game Boy Advance SP Brightness Switch Replacement: 手順 3、 1の画像 1
    • Use your fingers or a plastic opening tool to remove the battery from the device.
    • Caution: Please exercise caution when handling the battery. If it appears to be swelling or damaged at all it is considered a fire hazard.
  4. Nintendo Game Boy Advance SP Brightness Switch Replacement, Back Cover: 手順 4、 2の画像 1 Nintendo Game Boy Advance SP Brightness Switch Replacement, Back Cover: 手順 4、 2の画像 2
    • Remove four 6.5 mm screws from the corners of the back cover using a tri-point Y00 screwdriver.
    • Remove two 4.6mm screws from the top-center and bottom-center of the device using a tri-point Y00 screwdriver.
  5. Nintendo Game Boy Advance SP Brightness Switch Replacement: 手順 5、 1の画像 1
    • Lift the back cover off of the device.
    • Potential for device damage: These inner components are vulnerable to static electricity. Exercise caution when handling these next steps to prevent damaging the device.
    • Look out for the power switch that can fall out when taking the back cover off.
  6. Nintendo Game Boy Advance SP Brightness Switch Replacement, Motherboard: 手順 6、 1の画像 1
    • Using a Phillips #00 screwdriver, remove the three Phillips #00 4 mm long screws that hold the motherboard to the button panel.
  7. Nintendo Game Boy Advance SP Brightness Switch Replacement: 手順 7、 1の画像 1
    • Be careful not to tear the ribbon cable that's connected to the screen. If you tear it, games will not appear on the device's screen!
    • Flip the motherboard up and rest it on the other half of the device, so that the back of the buttons are visible as seen in the picture.
  8. Nintendo Game Boy Advance SP Brightness Switch Replacement, Brightness Switch: 手順 8、 1の画像 1
    • With your fingers, lift the track pad out off the brightness switch.
    • Keep the track pad clean. A dirty or dusty track pad will lead to the brightness switch not working when you press it.
  9. Nintendo Game Boy Advance SP Brightness Switch Replacement: 手順 9、 1の画像 1
    この手順で使用する道具:
    • Using tweezers, lift the brightness switch out of the Game Boy Advance SP.
終わりに
15 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
DJ Pantone
メンバー登録日: 01/11/13
1,944 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 17-22, Forte Winter 2013 Cal Poly, Team 17-22, Forte Winter 2013人のメンバー
CPSU-FORTE-W13S17G22
4 メンバー
41のガイドは作成済み
1件のガイドコメント
Thank you so much
sherzadcemil - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 28
過去 30 日: 121
今までの合計 20,397
