メインコンテンツにスキップ
はじめに
If the springs work properly but are not properly mounted to the cartridge tray, follow these instructions.
  1. Remove the six 13.25mm Phillips screws on the bottom of the game console with a #2.5 flathead screwdriver. The screws are recessed about 40 mm.
    • Remove the six 13.25mm Phillips screws on the bottom of the game console with a #2.5 flathead screwdriver.
    • The screws are recessed about 40 mm.
    • Flip the game console right side up and take off the top by pulling it up and away from the rest of the device with your hands.
  2. Remove the seven 13.25mm Phillips screws from the metal cover with a Phillips head #2 screwdriver. Remove the metal cover by pulling it up and away from the rest of the console with your hands.
    • Remove the seven 13.25mm Phillips screws from the metal cover with a Phillips head #2 screwdriver.
    • Remove the metal cover by pulling it up and away from the rest of the console with your hands.
  3. iPhoneのバッテリーキット
    Only $29.99
    Buy Now
    iPhoneのバッテリーキット
    Only $29.99
    Buy Now
  4. Remove the two silver 17.45mm Phillips screws from the cartridge tray using a Phillips head #2 screwdriver. Remove the two bronze 13.25mm Phillips screws from the cartridge tray using a Phillips head #2 screwdriver. Slide the cartridge tray toward you, away from the 72-PIN connector, and off the motherboard assembly.
    • Remove the two silver 17.45mm Phillips screws from the cartridge tray using a Phillips head #2 screwdriver.
    • Remove the two bronze 13.25mm Phillips screws from the cartridge tray using a Phillips head #2 screwdriver.
    • Slide the cartridge tray toward you, away from the 72-PIN connector, and off the motherboard assembly.
  5. Underneath the cartridge tray is a black tab/lip (see marker).
    • Underneath the cartridge tray is a black tab/lip (see marker).
    • Make sure you orient this tab underneath the motherboard in addition to orienting the tray on top. Failure to do so will bow the cartridge tray and place stress on the component.
  6. Use your fingernail to squeeze down on one side of the spring and reposition the spring back on to the plastic nipple attached to the smaller part of the game cartridge frame.
    • Use your fingernail to squeeze down on one side of the spring and reposition the spring back on to the plastic nipple attached to the smaller part of the game cartridge frame.
まとめ
4 の人々がこのガイドを完成させました。
nicholasweiser
メンバー登録日: 2010年09月22日
2,406 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 14-40, Forte Fall 2010 Cal Poly, Team 14-40, Forte Fall 2010人のメンバー
CPSU-FORTE-F10S14G40
4 メンバー
12のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 20
今までの合計 6,844
