必要な工具と部品
スパッジャーを使って、マザーボードからマイクケーブルを持ち上げます。
Note that the WiFi board has already been removed here! Including this extra step would be convenient here '-)
スパッジャーの平面側先端を使って、下部ディスプレイデータケーブルのZIFコネクタ上の固定フラップを跳ね上げます。
スパッジャーの鋭利な先端を使って、マザーボード上のコネクタから下部ディスプレイデータケーブルを引っ張ります。
-This is where you can replace the charger port. i may change this comment later from May 21-June 5
スパッジャーの平面側先端を使って、マザーボード上のソケットからバッテリーケーブルを持ち上げます。
The battery connectors (socket) on the mother board are extremely fragile, so care should be taken to avoid breaking them.
Other than this, the instructions given are precise and straighforward. I do agree with the other comments about step 20.
マザーボードを上部ケースに固定しているネジを外します:
2.5mmプラスネジ(シルバー) 1本
3.7mmプラスネジ(黒) 4本
the battery connector was (for me) extremely hard to remove. I broke the socket completely off the board hand had to hard solder it directly back.
スパッジャーの平面側先端を使って、上部ディスプレイデータケーブルのZIFコネクタ上の固定フラップを跳ね上げます。
スパッジャーの鋭利な先端を使って、マザーボードの下側にあるコネクタから上部ディスプレイデータケーブルを引っ張ります。
This step is unnecessary. The ribbon is a total pain in the butt to get back in, and if you dont get it PERFECT, the DS will not even fire back up. Unless it is absolutely necessary to remove it... DON'T !!! ( Personal experience, Everything else was SPOT ON) THANK YOU FOR THE HELP, saved me a lot of $$$
Jerod Cook - 返信
I put mine back together for my daughter with the new bottom screen, but it won't power on. It tries but won't I'm assuming that this ribbon is the cause.
The instructions are perfect though! Great thing to have these instructions it's a tremendous help! :-)
YHWH is the god of all knowledge. Put a piece of transparent tape on the ribbon cable to give more leverage to pull the cable up to slide it into the slot. Also turn the motherboard slightly so that you can get it closer to the cable.
I didn't get mine completely reinserted at first. The symptom I experienced when powering it back on is the power light comes on briefly and the bottom screen light flashes, then they both shut off. No flash from the upper display. Had to try reinserting 3 times before I had it in completely. I agree, DON'T REMOVE if you don't have to.
コンソールを裏返しにした状態で、DSi XLをわずかに開口します。
上部ケースから下部ディスプレイを押し上げて離します。
DSi XLから下部ディスプレイを取り外します。
デバイスを再度組み立てるには、この説明書の逆の順番で組み立ててください。
2 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
railgunさんは世界中で修理する私たちを助けてくれています! あなたも貢献してみませんか?
翻訳を始める ›
コメント 1 件
Hello,
i was wondering if the antenna from the dsi xl was the same as the one from the normal dsi?
rust/white powder built up on a screw and can’t unscrew it
Eco - 返信
