はじめに
Turn up the stereo sound on the DSi XL by replacing the volume control switch.
必要な工具と部品
Remove the two Phillips screws securing the battery cover to the back of the handheld console.
Lift the battery cover off the back of the DSi XL.
Remove the four rubber screw covers on the lower case by prying them up with a push pin.
Remove the two gold 4.0 mm Phillips screws securing the left shoulder button assembly to the lower case.
Lift the left shoulder button assembly from the lower case.
The components of the left shoulder button assembly:
Left shoulder button
Shoulder button spring
Retaining pin
Left shoulder button support panel
On the inside of the battery compartment, use the tip of a spudger to detach the metal latch securing the volume control switch in place.
2 の人々がこのガイドを完成させました。
