はじめに
Get your dual-screen functionality back with a new upper display.
Remove the two Phillips screws securing the battery cover to the back of the handheld console.
Lift the battery cover off the back of the DSi XL.
Remove the four rubber screw covers on the lower case by prying them up with a push pin.
With the console still upside-down, open the DSi XL slightly.
Push the lower display away from the upper case.
Remove the lower display from the DSi XL.
Turn the DSi XL over and open the display.
Use a pushpin to remove the four plastic screw covers on the front bezel.
Remove the Phillips screw holding the metal securing bracket in place.
Lift the metal bracket off the camera.
Lift the Wi-Fi antenna off the front display bezel.
De-route the Wi-Fi antenna cable from its grooves at the bottom of the front display bezel.
Lift both of the speakers from their seats on the front display bezel.
To separate the upper LCD and speakers, desolder the contacts on the orange ribbon cable.
For detailed instructions on how to solder this type of connection, see our guide for repairing soldered connections.
Upper LCD remains
2 の人々がこのガイドを完成させました。
