メインコンテンツにスキップ
Nintendo DSi XL Stylus Housing Replacement
必要な工具と部品
  1. Nintendo DSi XL Stylus Housing Replacement, Battery: 手順 1、 2の画像 1 Nintendo DSi XL Stylus Housing Replacement, Battery: 手順 1、 2の画像 2
    • Remove the two Phillips screws securing the battery cover to the back of the handheld console.
    • Lift the battery cover off the back of the DSi XL.
  2. Nintendo DSi XL Stylus Housing Replacement: 手順 2、 1の画像 1
    • Lift the battery from the DSi XL.
  3. Nintendo DSi XL Stylus Housing Replacement, Lower Case: 手順 3、 3の画像 1 Nintendo DSi XL Stylus Housing Replacement, Lower Case: 手順 3、 3の画像 2 Nintendo DSi XL Stylus Housing Replacement, Lower Case: 手順 3、 3の画像 3
    • Remove the four rubber screw covers on the lower case by prying them up with a push pin.
  4. Nintendo DSi XL Stylus Housing Replacement: 手順 4、 1の画像 1
    • Remove the following seven Phillips screws that secure the lower case to the rest of the DSi XL:
    • Four silver 5.3 mm screws
    • Two black 5.3 mm screws
    • One black 2.5 mm screw
  5. Nintendo DSi XL Stylus Housing Replacement: 手順 5、 3の画像 1 Nintendo DSi XL Stylus Housing Replacement: 手順 5、 3の画像 2 Nintendo DSi XL Stylus Housing Replacement: 手順 5、 3の画像 3
    • Turn the DSi XL over, and open the display.
    • Insert a spudger between the upper and lower case at the bottom left corner of the DSi.
    • Slide the spudger along the bottom edge of the upper case to release the latches securing the upper case to the lower case.
  6. Nintendo DSi XL Stylus Housing Replacement: 手順 6、 2の画像 1 Nintendo DSi XL Stylus Housing Replacement: 手順 6、 2の画像 2
    • Close the display and turn the DSi XL over.
    • Lift the lower case from the front edge.
    • Rotate the lower case away from the DSi.
    • The lower case cannot be completely removed yet, since it is still connected to the motherboard.
  7. Nintendo DSi XL Stylus Housing Replacement: 手順 7、 2の画像 1 Nintendo DSi XL Stylus Housing Replacement: 手順 7、 2の画像 2
    • Using a spudger, pry the SD card/right shoulder button connector off its socket.
    • Pry the volume button/left shoulder button connector off its socket on the motherboard with a spudger.
  8. Nintendo DSi XL Stylus Housing Replacement, Right Shoulder Button: 手順 8、 3の画像 1 Nintendo DSi XL Stylus Housing Replacement, Right Shoulder Button: 手順 8、 3の画像 2 Nintendo DSi XL Stylus Housing Replacement, Right Shoulder Button: 手順 8、 3の画像 3
    • Remove the two gold 4.0 mm Phillips screws securing the right shoulder button assembly to the back case.
    • Lift the right shoulder button assembly from the back case.
    • The components of the right shoulder button assembly:
    • Right shoulder button
    • Shoulder button spring
    • Retaining pin
    • Right shoulder button holding panel
  9. Nintendo DSi XL Stylus Housing Replacement, Stylus Housing: 手順 9、 1の画像 1
    • Remove the stylus from its housing on the right side of the DSi XL.
  10. Nintendo DSi XL Stylus Housing Replacement: 手順 10、 3の画像 1 Nintendo DSi XL Stylus Housing Replacement: 手順 10、 3の画像 2 Nintendo DSi XL Stylus Housing Replacement: 手順 10、 3の画像 3
    • Remove the three 4 mm gold Phillips screws securing the stylus housing to the lower case.
    • Using a spudger, lift the stylus housing off the lower case.
    • Remove the stylus housing from the handheld console.
終わりに
4 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Brett Hartt
メンバー登録日: 04/12/10
127,876 ポイント
143のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
135 メンバー
16,732のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 22
今までの合計 7,726
