メインコンテンツにスキップ
Nintendo DSi XL Right Shoulder Button Replacement
必要な工具と部品
  1. Nintendo DSi XL Right Shoulder Button Replacement, Battery: 手順 1、 2の画像 1 Nintendo DSi XL Right Shoulder Button Replacement, Battery: 手順 1、 2の画像 2
    • Remove the two Phillips screws securing the battery cover to the back of the handheld console.
    • Lift the battery cover off the back of the DSi XL.
  2. Nintendo DSi XL Right Shoulder Button Replacement: 手順 2、 1の画像 1
    • Lift the battery from the DSi XL.
  3. Nintendo DSi XL Right Shoulder Button Replacement, Lower Case: 手順 3、 3の画像 1 Nintendo DSi XL Right Shoulder Button Replacement, Lower Case: 手順 3、 3の画像 2 Nintendo DSi XL Right Shoulder Button Replacement, Lower Case: 手順 3、 3の画像 3
    • Remove the four rubber screw covers on the lower case by prying them up with a push pin.
  4. Nintendo DSi XL Right Shoulder Button Replacement: 手順 4、 1の画像 1
    • Remove the following seven Phillips screws that secure the lower case to the rest of the DSi XL:
    • Four silver 5.3 mm screws
    • Two black 5.3 mm screws
    • One black 2.5 mm screw
  5. Nintendo DSi XL Right Shoulder Button Replacement: 手順 5、 3の画像 1 Nintendo DSi XL Right Shoulder Button Replacement: 手順 5、 3の画像 2 Nintendo DSi XL Right Shoulder Button Replacement: 手順 5、 3の画像 3
    • Turn the DSi XL over, and open the display.
    • Insert a spudger between the upper and lower case at the bottom left corner of the DSi.
    • Slide the spudger along the bottom edge of the upper case to release the latches securing the upper case to the lower case.
  6. Nintendo DSi XL Right Shoulder Button Replacement: 手順 6、 2の画像 1 Nintendo DSi XL Right Shoulder Button Replacement: 手順 6、 2の画像 2
    • Close the display and turn the DSi XL over.
    • Lift the lower case from the front edge.
    • Rotate the lower case away from the DSi.
    • The lower case cannot be completely removed yet, since it is still connected to the motherboard.
  7. Nintendo DSi XL Right Shoulder Button Replacement: 手順 7、 2の画像 1 Nintendo DSi XL Right Shoulder Button Replacement: 手順 7、 2の画像 2
    • Using a spudger, pry the SD card/right shoulder button connector off its socket.
    • Pry the volume button/left shoulder button connector off its socket on the motherboard with a spudger.
  8. Nintendo DSi XL Right Shoulder Button Replacement, Right Shoulder Button: 手順 8、 3の画像 1 Nintendo DSi XL Right Shoulder Button Replacement, Right Shoulder Button: 手順 8、 3の画像 2 Nintendo DSi XL Right Shoulder Button Replacement, Right Shoulder Button: 手順 8、 3の画像 3
    • Remove the two gold 4.0 mm Phillips screws securing the right shoulder button assembly to the back case.
    • Lift the right shoulder button assembly from the back case.
    • The components of the right shoulder button assembly:
    • Right shoulder button
    • Shoulder button spring
    • Retaining pin
    • Right shoulder button holding panel
終わりに
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Brett Hartt
メンバー登録日: 04/12/10
127,897 ポイント
143のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
135 メンバー
16,817のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 26
過去 30 日: 93
今までの合計 9,250
