はじめに
Nintendo DSi XL の破損した上部LCDの交換をするには、このガイドを参照してください。
必要な工具と部品
スパッジャーを使って、マザーボードからマイクケーブルを持ち上げます。
Note that the WiFi board has already been removed here! Including this extra step would be convenient here '-)
スパッジャーの平面側先端を使って、下部ディスプレイデータケーブルのZIFコネクタ上の固定フラップを跳ね上げます。
スパッジャーの鋭利な先端を使って、マザーボード上のコネクタから下部ディスプレイデータケーブルを引っ張ります。
-This is where you can replace the charger port. i may change this comment later from May 21-June 5
スパッジャーの平面側先端を使って、マザーボード上のソケットからバッテリーケーブルを持ち上げます。
The battery connectors (socket) on the mother board are extremely fragile, so care should be taken to avoid breaking them.
Other than this, the instructions given are precise and straighforward. I do agree with the other comments about step 20.
マザーボードを上部ケースに固定しているネジを外します:
2.5mmプラスネジ(シルバー) 1本
3.7mmプラスネジ(黒) 4本
the battery connector was (for me) extremely hard to remove. I broke the socket completely off the board hand had to hard solder it directly back.
スパッジャーの平面側先端を使って、上部ディスプレイデータケーブルのZIFコネクタ上の固定フラップを跳ね上げます。
スパッジャーの鋭利な先端を使って、マザーボードの下側にあるコネクタから上部ディスプレイデータケーブルを引っ張ります。
This step is unnecessary. The ribbon is a total pain in the butt to get back in, and if you dont get it PERFECT, the DS will not even fire back up. Unless it is absolutely necessary to remove it... DON'T !!! ( Personal experience, Everything else was SPOT ON) THANK YOU FOR THE HELP, saved me a lot of $$$
Jerod Cook - 返信
I put mine back together for my daughter with the new bottom screen, but it won't power on. It tries but won't I'm assuming that this ribbon is the cause.
The instructions are perfect though! Great thing to have these instructions it's a tremendous help! :-)
YHWH is the god of all knowledge. Put a piece of transparent tape on the ribbon cable to give more leverage to pull the cable up to slide it into the slot. Also turn the motherboard slightly so that you can get it closer to the cable.
I didn't get mine completely reinserted at first. The symptom I experienced when powering it back on is the power light comes on briefly and the bottom screen light flashes, then they both shut off. No flash from the upper display. Had to try reinserting 3 times before I had it in completely. I agree, DON'T REMOVE if you don't have to.
デバイスを再組立する際は、これらのインストラクションを逆の順番に従って作業を進めてください。
16 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
6 件のコメント
I think a soldering tool needs to be added to the tool list. It may be a given for pros, but for amateur fixit wannabes this could be useful information to have before step 44.
Why is there two Upper LCD Replacements here? makes no sense, Can i have a explanation for this? One is "Difficult", and another is "Very difficult"
Santi12008 - 返信
there's two different options?? why does this got to be so complicated. is there any place that does replacements for me?
You wait til the final STEP 44 to mention soldering is required…!?!
Andy Bravo - 返信
PLEASE add soldering into required tools… I just spent an hour disassembling the %#*@ thing to be told I need to buy a soldering kit.
this is why you always read the entire guide at least once before you start a project. but I do agree it should be in the tools list.
rust/white powder built up on a screw and can’t unscrew it
Eco - 返信
