メインコンテンツにスキップ
Nintendo DSI Battery Replacement
必要な工具と部品
  1. Nintendo DSI Battery Replacement, Setup and Parts: 手順 1、 1の画像 1
    • To begin the battery replacement, have all your tools and parts nearby and ready to go.
    • Nintendo DSI
    • #00 2.0mm Phillips Head Screwdriver OR Precision Screwdriver Kit
    • Spudger or Prying Tool
    • Nintendo DSI Battery
  2. Nintendo DSI Battery Replacement, Accessing the battery compartment: 手順 2、 3の画像 1 Nintendo DSI Battery Replacement, Accessing the battery compartment: 手順 2、 3の画像 2 Nintendo DSI Battery Replacement, Accessing the battery compartment: 手順 2、 3の画像 3
    • On the backside of the DSI, you'll notice a plastic panel with two screws off to the side. Unscrew both screws using a #00 Phillips head screwdriver or an appropriately sized screwdriver bit.
    • Unscrew both screws using a #00 Phillips head screwdriver or an appropriately sized screwdriver bit. The screws will stay with the panel during removal.
    • Lift the plastic panel up and away from the DSI. If the panel stays in place after unscrewing, hold the DSI upsidedown and gently tap the device. This should free the panel.
  3. Nintendo DSI Battery Replacement, Removing and Replacing the battery pack: 手順 3、 3の画像 1 Nintendo DSI Battery Replacement, Removing and Replacing the battery pack: 手順 3、 3の画像 2 Nintendo DSI Battery Replacement, Removing and Replacing the battery pack: 手順 3、 3の画像 3
    • Once you've removed the plastic panel, you'll have full access to the battery pack.
    • Using the spudger/prytool or gently tapping the DSI, lift and remove the battery upwards and away from the device.
    • [IMPORTANT] when installing the replacement battery pack, make sure to line up the positive and negative terminals on the battery to those on the battery compartment on the DSI
  4. Nintendo DSI Battery Replacement, Finishing up: 手順 4、 1の画像 1
    • Once you've reinstalled/replaced the battery pack. Reinstall the plastic panel, making sure to line up the plastic hinges on the side adjacent to the screws.
    • Drop the panel into place and retighten both of the screws.
終わりに
Congratulations! You just replaced your Nintendo DSi's battery!
4 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Edrick Tong
メンバー登録日: 01/26/22
217 ポイント
1ガイドが承認済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 23
過去 30 日: 77
今までの合計 1,871
