メインコンテンツにスキップ
Nintendo DS Upper LCD Screen Replacement
必要な工具と部品
  1. Nintendo DS Upper LCD Screen Replacement, Battery: 手順 1、 3の画像 1 Nintendo DS Upper LCD Screen Replacement, Battery: 手順 1、 3の画像 2 Nintendo DS Upper LCD Screen Replacement, Battery: 手順 1、 3の画像 3
    • Remove the cartridge from the console.
    • Use a Phillips #00 Screwdriver to remove the screw securing the battery door to the rear case.
    • Remove the battery door.
    • In the images, it shows that the fixer is using a flathead screwdriver. This flathead screwdriver will work just like the Phillips #00 Screwdriver.
  2. Nintendo DS Upper LCD Screen Replacement: 手順 2、 1の画像 1
    • Use a plastic opening tool or spudger to pry out the battery from the bottom. If a plastic opening tool or spudger isn't available, your fingernails may work.
  3. Nintendo DS Upper LCD Screen Replacement: 手順 3、 1の画像 1
    • Remove the battery from the Nintendo DS.
  4. Nintendo DS Upper LCD Screen Replacement, Back Panel: 手順 4、 1の画像 1
    • Remove the seven 6.4mm Y00 screws located on the back.
    • If your DS has a lanyard attached to it, you can remove it to make the process of opening the top-left screw easier.
  5. Nintendo DS Upper LCD Screen Replacement: 手順 5、 3の画像 1 Nintendo DS Upper LCD Screen Replacement: 手順 5、 3の画像 2 Nintendo DS Upper LCD Screen Replacement: 手順 5、 3の画像 3
    • With your hands, pry the back panel off the main case.
    • Separate the back from the front, and set it aside.
  6. Nintendo DS Upper LCD Screen Replacement, Motherboard replacement.: 手順 6、 1の画像 1
    • Using a Phillips #00 screwdriver, remove the four screws on the circuit board.
    • Be careful NOT to slip with the screwdriver, you can damage the circuit board!
  7. Nintendo DS Upper LCD Screen Replacement: 手順 7、 3の画像 1 Nintendo DS Upper LCD Screen Replacement: 手順 7、 3の画像 2 Nintendo DS Upper LCD Screen Replacement: 手順 7、 3の画像 3
    • Unlock the two large ribbon cables by moving the black clip up.
    • Carefully pull the ribbon cables down and out with your fingers.
    • Do not use pliers to pull the cables, as they can be damaged easily.
  8. Nintendo DS Upper LCD Screen Replacement: 手順 8、 2の画像 1 Nintendo DS Upper LCD Screen Replacement: 手順 8、 2の画像 2
    • Locate the two small ribbon cables, beneath the rightmost large ribbon cable.
    • Slide the locks for the small ribbon cables down to the side, and remove the cables.
    • It may be useful to use tweezers to remove the small ribbon cables.
    • Be careful not to damage the delicate ribbon cables.
  9. Nintendo DS Upper LCD Screen Replacement: 手順 9、 2の画像 1 Nintendo DS Upper LCD Screen Replacement: 手順 9、 2の画像 2
    • Locate the Wifi antenna pigtail connector.
    • Remove the antenna by grasping it at the head with tweezers. Using a slight rocking motion, pull up to dislodge the connector.
  10. Nintendo DS Upper LCD Screen Replacement: 手順 10、 1の画像 1
    • Feed the ribbon cables through the opening on the board.
    • Pull up and remove the circuit board, and set it aside.
  11. Nintendo DS Upper LCD Screen Replacement, Top LCD Screen: 手順 11、 3の画像 1 Nintendo DS Upper LCD Screen Replacement, Top LCD Screen: 手順 11、 3の画像 2 Nintendo DS Upper LCD Screen Replacement, Top LCD Screen: 手順 11、 3の画像 3
    • Use a flathead screw driver or dental tool to remove rubber covers on screen.
    • Then using a #00 screw driver remove the screws beneath.
  12. Nintendo DS Upper LCD Screen Replacement: 手順 12、 3の画像 1 Nintendo DS Upper LCD Screen Replacement: 手順 12、 3の画像 2 Nintendo DS Upper LCD Screen Replacement: 手順 12、 3の画像 3
    • Using a soft plastic tool, pry the edges of the plastic case apart at the seam.
  13. Nintendo DS Upper LCD Screen Replacement: 手順 13、 3の画像 1 Nintendo DS Upper LCD Screen Replacement: 手順 13、 3の画像 2 Nintendo DS Upper LCD Screen Replacement: 手順 13、 3の画像 3
    • Separate the top cover from the body.
    • Using a Phillips #00 screwdriver, remove the screw holding the hinge cover in place.
    • Remove the hinge cover and set it aside.
  14. Nintendo DS Upper LCD Screen Replacement: 手順 14、 2の画像 1 Nintendo DS Upper LCD Screen Replacement: 手順 14、 2の画像 2
    • Feed the ribbon cables and the Wifi pigtail cable through the opening in the hinge cover.
    • Remove the yellow spacer, and set aside.
  15. Nintendo DS Upper LCD Screen Replacement: 手順 15、 2の画像 1 Nintendo DS Upper LCD Screen Replacement: 手順 15、 2の画像 2
    • Using a Phillips #00 screwdriver, remove the two screws holding down the speaker circuit boards.
    • Remove the two small circuit boards and set aside.
    • Be careful of the small red and black wires connecting the two circuit boards not to break them.
  16. Nintendo DS Upper LCD Screen Replacement: 手順 16、 3の画像 1 Nintendo DS Upper LCD Screen Replacement: 手順 16、 3の画像 2 Nintendo DS Upper LCD Screen Replacement: 手順 16、 3の画像 3
    • Move the black lock on the two large ribbon cables up with a pry tool, and gently pull out the two ribbon cables.
    • For the small ribbon cable, pull the lock downwards.
    • Gently pull out the small ribbon cable from the connector.
    • Set the two small circuit boards aside
    • Be careful not to damage the two delicate ribbon cables when removing them from the DS.
  17. Nintendo DS Upper LCD Screen Replacement: 手順 17、 2の画像 1 Nintendo DS Upper LCD Screen Replacement: 手順 17、 2の画像 2
    • Using a pry tool, gently lift the top screen out of the shell.
    • Set the top screen aside
終わりに
40 の人々がこのガイドを完成させました。
作成者
17人の作成者と共同で作成されました。
dnguye26
メンバー登録日: 10/28/09
694 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 18-3, Maness Fall 2009 Cal Poly, Team 18-3, Maness Fall 2009人のメンバー
CPSU-MANESS-F09S18G3
4 メンバー
28のガイドは作成済み
11 件のコメント
Unlike the DS Lite and later models, there is no reason to take apart the bottom portion of the original DS in order to remove the top screen. The first ten steps of this guide could be skipped.
PohTayToez - 返信
Thanks great advice
truenhete TrueNhero -
Can a ds lite screen be used to repair a ds??
David Moore - 返信
Nope, Nintendo engineered the Lite as a refinement of the original. Therefore almost every component is different! Likely to become cheaper to manufacture.
Del Riordan -
Can a ds lite screen be used to repair a ds one?? Lots of ds lite screens about......
David Moore - 返信
コメントを追加
統計データ:
過去 24時間: 24
過去 7 日: 206
過去 30 日: 1,086
今までの合計 102,696
