メインコンテンツにスキップ
Nintendo DS Main Circuit Board Replacement
必要な工具と部品
  1. Nintendo DS Main Circuit Board Replacement, Battery: 手順 1、 3の画像 1 Nintendo DS Main Circuit Board Replacement, Battery: 手順 1、 3の画像 2 Nintendo DS Main Circuit Board Replacement, Battery: 手順 1、 3の画像 3
    • Remove the cartridge from the console.
    • Use a Phillips #00 Screwdriver to remove the screw securing the battery door to the rear case.
    • Remove the battery door.
    • In the images, it shows that the fixer is using a flathead screwdriver. This flathead screwdriver will work just like the Phillips #00 Screwdriver.
  2. Nintendo DS Main Circuit Board Replacement: 手順 2、 1の画像 1
    • Use a plastic opening tool or spudger to pry out the battery from the bottom. If a plastic opening tool or spudger isn't available, your fingernails may work.
  3. Nintendo DS Main Circuit Board Replacement: 手順 3、 1の画像 1
    • Remove the battery from the Nintendo DS.
  4. Nintendo DS Main Circuit Board Replacement, Back Panel: 手順 4、 1の画像 1
    • Remove the seven 6.4mm Y00 screws located on the back.
    • If your DS has a lanyard attached to it, you can remove it to make the process of opening the top-left screw easier.
  5. Nintendo DS Main Circuit Board Replacement: 手順 5、 3の画像 1 Nintendo DS Main Circuit Board Replacement: 手順 5、 3の画像 2 Nintendo DS Main Circuit Board Replacement: 手順 5、 3の画像 3
    • With your hands, pry the back panel off the main case.
    • Separate the back from the front, and set it aside.
  6. Nintendo DS Main Circuit Board Replacement, Motherboard replacement.: 手順 6、 1の画像 1
    • Using a Phillips #00 screwdriver, remove the four screws on the circuit board.
    • Be careful NOT to slip with the screwdriver, you can damage the circuit board!
  7. Nintendo DS Main Circuit Board Replacement: 手順 7、 3の画像 1 Nintendo DS Main Circuit Board Replacement: 手順 7、 3の画像 2 Nintendo DS Main Circuit Board Replacement: 手順 7、 3の画像 3
    • Unlock the two large ribbon cables by moving the black clip up.
    • Carefully pull the ribbon cables down and out with your fingers.
    • Do not use pliers to pull the cables, as they can be damaged easily.
  8. Nintendo DS Main Circuit Board Replacement: 手順 8、 2の画像 1 Nintendo DS Main Circuit Board Replacement: 手順 8、 2の画像 2
    • Locate the two small ribbon cables, beneath the rightmost large ribbon cable.
    • Slide the locks for the small ribbon cables down to the side, and remove the cables.
    • It may be useful to use tweezers to remove the small ribbon cables.
    • Be careful not to damage the delicate ribbon cables.
  9. Nintendo DS Main Circuit Board Replacement: 手順 9、 2の画像 1 Nintendo DS Main Circuit Board Replacement: 手順 9、 2の画像 2
    • Locate the Wifi antenna pigtail connector.
    • Remove the antenna by grasping it at the head with tweezers. Using a slight rocking motion, pull up to dislodge the connector.
  10. Nintendo DS Main Circuit Board Replacement: 手順 10、 1の画像 1
    • Feed the ribbon cables through the opening on the board.
    • Pull up and remove the circuit board, and set it aside.
終わりに
20 の人々がこのガイドを完成させました。
作成者
18人の作成者と共同で作成されました。
kingdesmond
メンバー登録日: 10/27/09
2,050 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 18-3, Maness Fall 2009 Cal Poly, Team 18-3, Maness Fall 2009人のメンバー
CPSU-MANESS-F09S18G3
4 メンバー
28のガイドは作成済み
コメント 1 件
This was really helpful. Thank you!
Jess Anderson - 返信
コメントを追加
統計データ:
過去 24時間: 8
過去 7 日: 48
過去 30 日: 211
今までの合計 27,932
