メインコンテンツにスキップ
Nintendo DS Lite Lower Case Replacement
必要な工具と部品
  1. Nintendo DS Lite Lower Case Replacement, Battery: 手順 1、 2の画像 1 Nintendo DS Lite Lower Case Replacement, Battery: 手順 1、 2の画像 2
    • Unscrew the Phillips screw securing the battery cover to the lower case.
    • The screw remains captive to the battery cover.
    • Pry the battery cover upward with a spudger or fingernail, and lift out of the lower case.
  2. Nintendo DS Lite Lower Case Replacement: 手順 2、 1の画像 1
    • Wedge the edge of a spudger in between the side of the battery and the lower case housing and pry upward to dislodge the battery.
    • Remove the battery from the DS Lite.
  3. Nintendo DS Lite Lower Case Replacement, Lower Case: 手順 3、 2の画像 1 Nintendo DS Lite Lower Case Replacement, Lower Case: 手順 3、 2の画像 2
    • Use the tip of a spudger to pry both rubber feet off the DS Lite.
  4. Nintendo DS Lite Lower Case Replacement: 手順 4、 1の画像 1
    • Remove the following screws securing the lower case to the body of the DS Lite:
    • Two 4.3 mm gold Phillips screws
    • One 3.9 mm black Tri-Wing screw
    • One 3.3 mm silver Phillips screw
    • Three 5.5 mm silver Tri-Wing screws
  5. Nintendo DS Lite Lower Case Replacement: 手順 5、 3の画像 1 Nintendo DS Lite Lower Case Replacement: 手順 5、 3の画像 2 Nintendo DS Lite Lower Case Replacement: 手順 5、 3の画像 3
    • Insert the edge of a spudger in between the lower and upper case near the top right corner of the DS Lite.
    • Carefully run the spudger along the right edge of the DS Lite, creating an opening in the process.
    • Continue running the spudger along the backside of the DS Lite until the majority of the lower case has been separated from the upper case.
  6. Nintendo DS Lite Lower Case Replacement: 手順 6、 1の画像 1
    • Lift the lower case away from the rest of the DS Lite.
    • Pull carefully. Some units are sealed with adhesive, and pulling too hard can damage the power switch.
終わりに
33 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Matthew Newsom
メンバー登録日: 01/05/10
39,527 ポイント
67のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 30
過去 30 日: 175
今までの合計 27,371
